I was reading the pele minivid and the discussion about trick names and I began to wonder what the longest trick names would be. Post what you think the longest trick name is. For example “fakie swith blind hack donkey trey side flip.” Lol
Street names don’t even come close to Freestyle names in terms of length, but they do make a whole lot more sense.
Backwards seat on side stand up wheel walk pushing with left foot.
The shorter way of saying this would be (in my case) Switch fakie Daiki wheel walk
Except you used scuff and donkey kick, which are the same thing pretty much. The more correct version would be:
One Footed Backward Seat In Front Stand Up Coast
onefootbackwardsseatinfrontscuffdonkeykickstandupcoast
I also took the whole mention of a scuff of donkey kick part out because it wasn’t needed at all, the scuffing part would be the transition and not the actual trick. But if you wanted to make it longer you could go with which foot was doing the action!
Making it a Right side, one footed, backwards, seat in front, stand up, coast!
(yes I did just add the commas to make it longer)
Switch handed, reverse (hack), switch footed, blind, inward, side, Spencer, late, doubleback, seat in to stand up wheelwalk (position).
11 adverbs/adjectives
But not possible.
EDITED
The spencer and double back parts contradict eachother. Also I don’t think you can do an inward side anything.
How? so does hick and double back in a hickdoubleback contradict eachother?
and inward side (small)flips have been done.
Sorry you are right about the spencer one, it just looked really wierd when I read it.
It would be a 720 unispin with a double backflip. Once I typed it out like that it made more sense.
My bad.
And for the Inward side flips, I guess I just have the terminology wrong them.
What would an inward side flip be?
He has it labeled as ‘back’ but it isnt. 1:58
Wierd I couldn’t even see what happened in it.
Did he do a sidespin with a 180 body varial, in the opposite direction with a flip?
Does it have to have been landed or not?
The longest named one I’ve landed I think is an in-in inward varial side fakie flip.
Naw… I have to have landed something with a longer name…
heres the longest i can think of:
in to out, hacked, late, fakie, switch handed, switch footed, blind, inward, doubleside mammoth quadruplebackflip
Lol, you totally did not even word that right.
If you actually said it right it would probably be 3/5 as long.
So how does a fakiebackflip go? Needs to be either: …quadbackflip, fakie…quadflip; or …quadfakieflip
And what is a doubleside?
Oh, caught a mistake on mine and added.
100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000° unispin
I beat everyone.
Or you could say that just as
10^1678 unispin (did I get that right?? Im usually falling asleep in math class)
Much less long
My software puts the character count at 1800 without spaces.
So it’s 10^1799.
Either way, it isn’t be divisible by 90 so you will not land on the tire or pedals.
Which makes it much more easy to land!
