Hey everyone, after constantly researching through this forum and on the internet about a second unicycle, I have decided that I will eventually purchase a Torker AX 29". I am wondering if this will be okay for light/beginner muni trails and possibly urban trial stuff (steps/rails…). Other than that, I think I am pretty sure about everything else.
Thanks!
(P.S. I am not quite sure on a seat, I am thinking just upgrade the stock one myself (tempurpedic foam/air/gel/nice leather), but if anyone has anything to say on that, I would appreciate it! The search function will probably keep me covered.)
The Torker AX 29" is fine for road riding and light MUni, but I wouldn’t expect it to hold up to stairs and rails; it has a square-taper hub that wouldn’t last long if you’re doing drops on it.
The Nimbus is more or less equivalent to the Torker AX in terms of durability, and it looks like the unicycle.com model doesn’t have a handle, which is a big problem for a distance unicycle.
The AX will be fine then, even with the tire on it, I dont think you are going to be going on things steep enough for you that you will slip out all too easily.
Really? The Big Apple is better than the ExiWolf for muni? I’d heard okay things about the ExiWolf. Or is it better for hopping because of the larger air volume?
