Less Seat Post?
Well after getting the tire inflated today I attempted to mount…
Keyword: attempted :slight_smile:
No dropping or falling off occured because… I failed to remember that while
I’m about 5’4" my legs are unusually short. This creates a problem in reaching
the pedals! So I tried lowering the seat post about as far as I could get it to
go and lo and behold, I could just about reach the pedal. But then the post
stabs the wheel and well, that’s just counter productive to ridding the thing :slight_smile:
So, what’s the best way to cut off about an inch to inch&1/2 off the seat
post? Hacksaw?
I’m sure everybody’s just loving these posts from the unibie, it’ll stop soon…
I hope :-o
Re: Less Seat Post?
>post? Hacksaw?
The best thing to use is a pipe cutter which ensures a neat cut with no sharp
edges and also won’t deform the tube. You can usually get them in the plumbing
tools section of DIY shops.
Jon
Jonathan Marshall /| O O/ /|\ /| /|\ _/| / |\ LUNIs Unicycle Hockey Club
/| >>\ << |\ / E-mail rocket@jbmarshl.demon.co.uk /
| 0 _ o 0 |_/
Re: Less Seat Post?
Hey there,
You might want to consider picking up a tube cutter. It will make a much cleaner
cut and doesn’t take as much work as using a hacksaw. You should be able to pick
one up at your local hardware store (read Home Depot, they’re invading the
planet) for $25 or so, Canadian too!
A tube cutter looks something like this …
http://www.contractorstools.com/graphics/Hempe5.JPG
Enjoy …
Carl
> Keyword: attempted
> reaching the pedals! So I tried lowering the seat post about as far as I
> could get it to go and lo and behold, I could just about reach the pedal. But
> then the post stabs the wheel and well, that’s just counter productive to
> ridding the thing
> post? Hacksaw?
> soon… I hope :-o
Re: Less Seat Post?
I’ve used a hacksaw for this - very carefully, then file off the little bits of
metal. Cut off the minimum possible amount so that the post can be used later at
as wide a range of heights as possible. Cut it so that it misses stabbing the
wheel by a little (1cm or so).
Have fun getting the hang of riding it!
—Nathan
“hidden7” <hidden7@my-deja.com> wrote in message
news:hidden7-17245B.14484822122000@news.powersurfr.com
> Keyword: attempted
> ridding the thing
> post? Hacksaw?
> soon… I hope :-o
Re: Less Seat Post?
And so that you can raise it again once you learn to mount better. I like mine
as high as possible, now that mounting isn’t a problem.
Graham W. Boyes
If you receive something that says “Send this to everyone you know” pretend you
don’t know me.
“Nathan Hoover” <nathan@movaris.com> wrote in message
news:t47uvvl12upaec@corp.supernews.com
bits
> of metal. Cut off the minimum possible amount so that the post can be used
> later at as wide a range of heights as possible. Cut it so that it misses
> stabbing the wheel by a little (1cm or so).
> —Nathan
