Left/Front or Right/Rear
I need some help quick if it’s available. I’m at the bike shop getting a brand new brake lever/caliper set and it looks like the technician installed a right/front caliper and lever. Should it be a front/left set? I’m right handed.
From the brief research I did, I don’t think it matters.
You can change which sides the brake disc is on, but again, whichever side you prefer is up to you.
It generally makes only a slight difference.
I’m not exactly sure, but it depends on how you mount your lever and the brake model. If you mount it on the “mini handle” under the seat, then often the brake lever is mounted close to straight, so it doesn’t matter.
However, some people rotate it a bit one way or the other, especially if you have a special mount like an Ursli bar or Mad4One Saddle Handle. But then it also depdends on the brake model, as some are more or less “symmetric” with regards to the reservoir. I’m right handed and usually rotate mine to the left. On my Ursli bar I mount my left/front lever on the right side and rotate it about 40 degrees left, so the reservoir doesn’t prevent rotating and would allow more up to maybe 70 degrees (the other right lever would be max about 35 degrees). But it usually doesn’t make a big difference, but left for a right hander is generally a bit more optimal.
To add to this topic: I found that it does matter a bit. I installed a right hand brake lever and use it tilted to the left on my Mad4One lever adapter, which works fine. However, I keep the lever loosely attached to keep if from getting damage. But when the uni falls, the weight of the reservoir (and perhaps the tension of the cable) makes it naturally rotate back to the right. Eventually I gave up and tightened it almost all the way down.
