does any one know if this will work? will the nimbus frame be compatible with the KH hub and seatpost?
I think the hub should fit but not the seat post, I’m pretty sure KH posts are thicker than the Nimbus posts.
so, could i just add a nimbus frame and seatpost, but leave everthing else KH?
Yup
Just make sure you get the frame with the 42mm bearing holders to accommodate the splined hub.
But why?
If you are buying new, wouldn’t a <400 $ KH from AEB make more sense? The KH is a much better frame, and by the time you build something from pieces, it might cost less as well to just buy a whole KH.
