Koxx 32h ISIS hubs...
we are gunna try and do an adapter. so you will be able to use that post with any base. that will be after the bases though.
Any word on whether KH will be doing a 32 hole hub sometime in the future?
I remember him talking about it at CMW. Basically he said that it was not going to happen any time soon. Though he did mention the idea of selling key chain thingys that might just happen to be the right shape and size be able to replace the flanges on the new moment hubs.
I had the impression that the key chains were not going to happen but it would be a cool way of getting around people asking for built up 32 and 36 spoke unicycles.
A few months on, my interest in these has come back.
So has anyone managed to get one? From the specs of K-124 UK, they come with 6061 alu bodies now.
If anyone has pictures, that’d be awesome
I got one with the new style rim (not a Nowar rim).
My KH moments (from 2007/8?) fit on them. Currently though I have KH Sym cranks on the hub. I didn’t need to do anything with adding extra spacers. Though I did have to get the crank bolt pretty tight. So it is true isis.
I have not done anything big on the wheel set, but it seems to have decent strength for the lightness. The biggest I plan to go is only tricks down 6 sets, hand rails (of any size set), and maybe I’ll work on my gaps (rolling and sidehop) so if you want, I can post back here when it breaks with only soft use. I also won’t be riding that much for the next year or so though.
edit: I’m not sure about the 6061 bodies, and I’ll post pictures maybe soon, maybe not though.
how come you’re “not currently riding?”
Because I’m at home sitting in my chair on a computer. :stuck_out_tongue:
Complicated… but pretty much I got grounded for the summer from my dad. The whole situation I find very stupid; what I did I don’t think was that bad, and he overreacted way too much.
That’d be awesome if you could get some shots.
Apparently so, regarding the 6061 bodies. I would like confirmation.
Is there any online site with info/pics of the new Koxx wheels?
Here are some pictures. If you want more I can get some on monday. Just tell me more of what you want them of. I didn’t get any pictures of this, but on the other side of the hub there is the isis drive logo (not sure if makes it official or something) and under it says 32 Holes.
Looks sweet!
Can you possibly measure how wide the flanges are apart? Also, are the bearings the same unit used on the KH hubs? I know for a fact the older Koxx hubs used a shim between the bearing inner race and the spindle.
I’d like to know 'cos if these are the same 1-piece bearing dimension as the KH ones, it means I can run KH’s 40mm bearings on 'em. :slight_smile:
About 5.65cm measured from the exterior (not the center).
And the bearings do look very, very similar to the KH ones I have.
I used to ride a Koxx-one wheel in a KH frame, so it should be the same size of bearings.
totally missing the point there
it’s the inner diameter of the bearing that’s being talked about, not the standard OD which is 42mm.
i noticed the koxx old hubs had funny bearings which needed a shim jammed between the inner race and the spindle surface.
I really dislike my 32 hole rim, it got so messed up so fast…
i’ll never go 32. i thought about it once, but only cause i have a 48 hole nimbus hub and they don’t make 48 hole rims anymore.. cept for quax i guess. i was mad when they did away with 48 spoke.
I’m taking a gamble with the ISIS 32 hubs. For several little little reasons it might not work out well with my frame.
My absolute last resort is to phone up Profile and ask them to make me a 32h hub. For me, 32h rims are easy and cheap to get a hold of, whereas if I want 36h like a KH… it’ll set me back a lot
Is there any site anywhere (aside from the non-working K1 site) that has info or more detailed specs of the new 32h ISIS hubs? I wonder if the ‘light’ version is done in 32h too?
In those pictures was the silver frame a EB frame or what?
Nope, that’s it’s own brand frame.
What dp you mean by that he made it or what?
