Hi all!
I own a KH24" uni and unfortunately one spoke broke three weeks ago. Since then it hasn’t been used because it seems to be almost impossible to get replacement spokes with 230mm x 2,3mm. A guy at a bike shop told me, that it would be also possible to use 2mm spokes. Is this really true?
yes, you can use 14 gu. (2mm) spokes. In fact, I prefer them over 13 gu.
Wow, fast answer. Thanks
But please note I got a KH24 2008 edition. I read, that the 2mm spokes are only used for 2009er KH unis. Would there be any recognizeable loss in stability if I would only use 2mm spokes (for now it would be only one)
No, there are no discernable differances between the two (other than weight). 2mm is a standard for a reason, they’re light, strong, and cheap.
Enjoy riding your KH again! Mine’s been treating me well these past two years.
But then I have two, maybe silly, questions:
How can a 2mm fit into 2,3mm hole of my KH24, when a nipple of a 2mm spoke wont’ fit on my 2,3mm spokes? (I have tried that)
Why arent’t this unis shipped with 2mm spokes then?
Thanks for your patience
I’m pretty sure it will fit in both the spoke hole on the hub and the nipple hole on the rim. If it doesn’t, you can use a spoke washer to make it fit (which I advise regardless because it builds a much stronger spoke/rim interface)
