Hi guys. Does any one know if 2005 KH hub fit into a Nimbus trials?
yup, think so ![]()
from what i recall, bearings belonging to the kh hub have a OD of 40mm, the nimbus frame takes 42mm OD.
a shim should be able to sort this problem out.
also im not sure on the spcers required on the axel.
otherwise i think it should work
Thanks, I have a KH that I can measure bearing OD but not a Nimbus trials. I have a Nimbus Muni., is that the same hub as the trials.
Thanks again
The KH are 42mm OD
