IUF 5km competition - which 24" unicycle
ok in that case you’re right with the 100m and 800m. I just imagined the chance of getting a good time with those would be nihil compared to other participants.
So far I’ve been going longer trips 10-15km as I figured, the more I ride, the more at home I will be with the 24" and thus can go faster. Real sprints I find difficult and always end up having to focus on staying in balance, which then slows down.
For many people, participating in competitions is about achieving a good time. For many others, it’s about having a good time, if you see what I mean. Hence, the “other participants” are not a homogeneous group, but achieve wildly different results, and you would simply fit somewhere in between, also on 100m and 800m. Indeed, staying in balance is an important aspect of unicycle racing, I daresay for almost all riders but certainly for me as well. And yes, it holds me back from going all-out.
When I participated in my first Unicon in 2006, I was somewhat like you. I did not enter the sprint races, only the 10k (on 24"). I had only done long rides by way of training, and at Unicon achieved a time of 41 minutes. At the next Unicon in 2008, having seen the track races in 2006, I also did 100m, 400m and 800m. Of course I trained beforehand on my sprints (as well as 10k). And here it comes: I noticed that my 10k performance improved significantly because of the sprint training, I think it went down to 36 minutes.
I’ve put in quite some time on the 24". Yesterday did my regular 10km round and there are a few places I need to hop off to get through gates on the cycle path that control the free-roaming cattle. But I am around 25 mins per 5km now.
On facebook I saw this reel come by:
Unicycle Japan 24" 100m. A lot needs to happen if I ever want to spin as fast as them. It is amazing to watch.
Also I notice that they all take off while holding a pole. So far I’ve only been free-mounting. Things like lampposts aren’t in the middle of the road. Any suggestions on where or how I can practise this, would be welcome
https://www.facebook.com/reel/1045639911654524
in the 100m race they are all riding over 25km/hr. The best 10km standard riders usually maintain 20-21km/hr. I wouldn’t use the 100m as a benchmark.
why not lighten up your tire a bit? I still have the duro on my 24 but I switched up to a lighter maxis holly roller for riding mixed surfaces on my 26 Oracle. I’m not saying that’s the tire you should get and I’m not sure what the 24 selection looks like. I feel you should still be able to find a wide ish tire (2.5 and up )with a less aggressive tread and still lightening it up and getting less rolling resistance.
uhm just re-read what you said…
20km / hour on a 24"??? I can hardly reach that with the 36" Im not that confident on the 36" but my leisure ride is at 17 kph. With the 24" I can do 5km at 25 mins at the moment, so just over 10kph, maybe 11 per hour.
@Bug72 I also have a 24" muni with a very heavy tire. By comparison the 24 road uni is very light and I like the width of the tire. I’ve grown quite accustomed to it. It is just the spinning I find difficult and that is mostly because of my forwards/backwards sway.
When I did the 16km run yesterday, there was an uphill section. That helped very much with the forward lean and I could ride pretty fast up the hill.
yeah sounds about right…
Unicon 20 standard 10k results - top 6 men and 2 women break a 20kph average.
a 24/26 standard has a max diameter of 618mm, to hit 20kph means holding an average of about 172rpm. Hitting 25kph is 215rpm.
While doing it on 125s definitely makes it harder 170-220+rpm is definitely both do-able and hold-able if you place no value in the continued existence of your knees…
