I just bought a unicycle Nimbus II Freestyle 24"
and i extremely want to turn it into a SEMI STANDARD-MUNI.
I don’t expect it to be so strong or go into a forest
So , The question is
1.) will a 2.5" wheel fit in the frame ? if not, what is the biggest size that could fit in that frame ?
2.) If I want to upgrade my unicycle to a SEMI STANDARD-MUNI, do i have to change the wheel set or just the inner tube and Tire or inner tube + tire + Rim
Yes, that uni will take a 2.5" tire. 2.6" is probably the largest that will fit.
Yes, you can replace the tire (and tube) and do some muni. Bear in mind that the max tire size is smaller, the rim is narrower, and the cranks are shorter than a purpose built 24" muni.
There are plenty of threads discussing tires that fit this uni, about muni on this model, about this uni vs a purpose built muni, et cetera.
Please direct your attention to the search box in the top right corner of your web browser. The search box is your friend. Love it. Squeeze it. Call it George.
