I need to install bearings on my KH 27.5. Alas, the seat post cuttings I have are from 25.4mm which are not big enough to fit around the axle. I’m going to go to the hardware store to look for something that will work for this. Any suggestions for this? What kind of pipe is best for it? Or is there a tool that can be used to push on the bearing?
I typically use a long socket from an impact wrench set, whichever smallest one that fits over the spindle without hitting it.
If you don’t have a socket set, perhaps you have some vernier calipers you can use to measure the diameter of the spindle so you can buy a pipe that will fit? If not, I’d highly recommend getting one I use calipers often when measuring parts for my unis
pipe cuttings (from seatposts or something else) are also my favorite tool for this task. However, as I hadn’t the matching diameter for my q-axle bearings on hand, I used a stack of q-axle spacers. It was a bit fiddly but worked.
I have a long length of 10mm studding with various spacers , washers and tubes of different sizes I’ve accumulated over the years which I use to wind on and squeeze on bearings, I’m not a fan of knocking bearings on.
Double stacking the spacers and using the crank to push it on should work. (Or more spacers if you happen to have them). Piece of wood on the crank to her on to protect them of course if you need to hammer, but maybe even using the bolt to tighten down works.
Otherwise take the bearings to the hardware store and see if they have a pipe with slightly larger ID, chances are probably decent that there are something.
I’ve always used the crank/bolt/spacers to install a bearing. Works like a charm with ISIS cranks/hubs. I’m pretty sure it should work with KH Boundary (Q-axle) as well.
If you have an old crank you can hammer it on to push the bearing, then again with a spacer (this usually deforms aluminum spacers a little so i like to use one until it gets ugly. If you’re careful you won’t drive the crank on far enough to need to use the puller to get it off
