Oh, wow, so then you must have helped him track me down! He found me a few years after he took the photo in 2009 and invited me to a photo exhibition where the image was featured. When I arrived at the exhibition, to my surprise I saw that he had blown the photo up to four feet wide and made it the centerpiece of the show. You can see a blog about it here:
To my further astonishment, the photographer informed me that the photo he took of me was his most successful and best selling photograph to date! At the exhibition, I signed a release relinquishing any financial claims to the photo, but I would never have asked him for any money, in any case. I think it helps him sell the photo more easily. He was nice enough to send me (an average size) copy of the photo for free that my parents still have hanging on their living room wall. The best part was hearing him tell me about the day he took the photo. He was out walking around the City on the day of the blizzard and the way he described it was: He caught a glimpse of me out of the corner of his eye, and like a hunter spotting prey, he quickly grabbed his gear (a camera rather than a gun), pressed the shutter at just the right moment and got the shot! Amazing! Clearly a talented guy,
A gyroplane is the general term for rotorcraft that have unpowered rotors and obtain thrust from a propeller in either a pusher or tractor configuration. āGyrocopterā was a trademarked term for a type of gyroplane (I think the Benson kits, but Iām not 100% certain) that became used interchangeably with the term gyroplane, though āgyrocopterā was most commonly used to refer to open frame models of gyroplanes. The term āautogyroā is also used interchangeably with gyroplane and gyrocopter, but typically refers to the gyroplanes of the early days (such as Cierva and Pitcairn) that had stub wings and a tractor propeller. Gyroplanes have experienced a resurgence in popularity, especially in Europe. A German manufacturer has sold over 3,000 gyroplanes and now offer a fully-assembled, type-certified version (though itās certified under a lesser used standard and the only commercial utilization that is allowed under that certification is flight training). Gyroplanes are fun, easy aircraft to fly. I like them a lot.
I have two solar-powered aircraft. One is a Northwing ET 180 and the other is a Wills Wing Spectrum 165. They are both hang gliders. The reason I refer to hang gliders as āsolar-powered aircraftā is because the main way hang glider pilots obtain lift (at sites other than where ridge lift is the main source) is to find thermals and corkscrew upward in the core of the thermal (at ascent rates ranging from a couple hundred feet per minute to up to around 2000 fpm in a real strong thermal). Thermals are formed when the sun heats the surface of the earth (or chicken coop roofs or anything else that gets hotter than the surrounding air) and that hot air rises. So itās kind of like a hot air balloon, but the sun does the heating instead of a propane-powered flame and instead of the hotter air being contained in a balloon, you have to go find it. Hereās a video of one of my flights at one of the best flying sites in the country:
Iām not that good of a pilot, but I sure do have a lot of fun!
Definitely most of the frames (including the mad4one) wonāt fit without modification. A the M-series hubs were developed with Kris Holm, KH-Frames were always the only ones fitting on the hub out of the box. You can read more on this topic here:
Most frames (except KH) do not fit this measurements:
The generation M5 hubs may have some additional requirements but i guess, these measurement shown in the picture will remain the same.
What it takes to modify a QX-Frame is decribed in the linked thread. For the mad4one frame, thereās @muni_ben who comes to my mind first who has done the modification.
Regarding M4O frame: my #800 hub fits into my M4O frame without any modification. The only tricky point was to set up the inner disc brake - BrakeFast - as the caliper was too large too fit so I had to file the caliper base.
As @Maxence said, recent Mad4one frames fit Schlumpf hubs right out of the box. But yes, for older frames, the modification of shaving off the inner lip was necessary and Marco did that on request.
So basically the Oracle frame pairs with a 125mm hub and the Mad4One frame with a 100mm hub, so your choice of frame dictates your Schlumpf hub ā or vice-versaā¦
I really like the look of the Mad4One frames and I like the double brake tab (so you can run two brakes if you really want ā see Nathanās video in this thread: Uni Santa Needs a Brake) , however I think Iād go with the Oracle one for an in-board brake just to get a slightly stronger wheel. I donāt think I would consider an outboard brake with the geared hub for the reason of transmitting all the braking torque through the gear train. Keep in mind that Ed Pratt went round the world on an 36" Oracle and didnāt have any issues with the frame (!) ā they donāt come in so many nice colours though
With respect to cranks, as discussed, straight cranks on a 125mm hub would have about the same pedal spacing as KH Spirits on a 100mm hub ā as also mentioned above though Spirits may have the advantage that they stop you hitting the shift button by mistake ā you could run those no problem on a 125mm hub but the pedals would just be further apart. Likewise, hitting the shift button by mistake might not even be an issue for you with straight cranks (like VCX for example). Iāve never ridden a Schlumpf hub so I canāt comment, perhaps other with experience can say how much of an issue it is.
Happy to have helped and itās be fun reading about your piloting + photo fame and the chain of events that led up to this becoming known to you.
Iām always amazed by how so many unicyclists have such cool and interesting stories to share
I should say on the frame topic, itās really good to hear that Mad4One newer frames, work out of the box.
I really like the look of them and thatās likely where Iād go with a 29er GUni.
For a 36er I would still lean to getting a Flansberrium frame. Heck maybe even something like this (now sold) one - Flansberrium 32" V-frame
In the thread on the above posting you can see @toutestbon amazing 36er V frame and basically it just goes to show what marvels the frames are from @jaco_flans - I donāt have one of his frames yet. But I am sure 2022 will be the year I order.
And you can be dead sure youāre getting one thatāll work with a schlumpf, customised to your needs and wishes.
I will be pleased to know more about the new torque reaction system Florian may have in store as with frames that arenāt KH Iāve always wondered how the little block thing would work. But it must just slot into any frame that doesnāt have the inside lip on the lower bearing mounts.
OK, I get it. From all the questions/comments I see you are assembling a unicycle to you own specifications. Not what I would do, just build your own from scratch. Jaco Flans is of the same mindset as I, if you want it right build it yourself.
On the frames, Nimbus has a 100mm dual disk tab Oracle style (gloss black aluminium) 36er frame now.
Roger informed me that UDC UK have them in stock but they havenāt yet had a chance to put them on the website. They should be available from next week.
I would presume that this is Schlumpf compatible out of the box and produced in part to ensure that Nimbus have a 36er frame compatible with current generation hubs. Thatās just speculation though - weāll just have to wait and see.
Some frames have the gap between frame and cap wider than this block, meaning that you will just lose it. I ended up cutting a little notch right in the middle of the upper lip and use just one of the two blocks.
Thanks! One of the things the hang gliding community has in common with the unicycling community is you get to meet lots of people who have cool and interesting stories to share. Iāve enjoyed hearing lots of them myself, so I am glad that it was fun for you to read about some of my adventures.
Thanks again to everyone for all the replies and very helpful information.
Ok, so based on the latest information youāve provided, apparently the Mad4one 36" is the only stock 36" frame that can be used with a Shlumpf hub (with disk brakes located on the inside of the frame) straight out of the box.
Iām not clear about whether the Nimbus Oracle 125mm will work right out of the-box with the 125mm version of Florianās hub. If anyone has this information, please let us know. Iām also not certain if the soon-to-be-available Nimbus 100mm dual disk tab Oracle style 36er frame will work right out of the-box, so any definitive information about that would also be most appreciated.
The possibility of accidentally hitting the shift button on the cranks terrifies me. Such an occurrence could easily ruin my day (or much worse). If the spirit cranks significantly reduces the possibility of this occurring, that would be reason enough for me to go with them. I am quite keen to hear peopleās thoughts on this subject. Is inadvertently hitting the shift button something that can easily occur with straight cranks? Are any Schlumpf riders who have accidentally hit the shift button following this thread? I am most interested in hearing about your experience and I would imagine others might be, too.
I have never ridden a Schlumph but I donāt like straight cranks because I hit the heel of my shoe on them all time. I have curved cranks similar to KH but actually Sun(a heck of a lot cheaper if you donāt need disc mounts) and I have never hit my heel on them unless it bounced off the pedal or something but thatās another problem in itself.
Thanks for your feedback, Unigoof. Iāve only ridden Cokers (which I think may have had a 125mm hub, but Iām not sure) with regular old, straight cotterless cranks and never had a problem. However, with a shift button on the cranks, even the remote possibility of inadvertently hitting that button concerns me, so I want to be sure to set up my geared 36er in a way thatās as safe for me as possible.
As to the initial question of the brake: I think the only real disadvantage other than the obvious complexity (but negligible compared to the Schlumpf hub) is that the braking power goes through the disc in high gear with an external disc. However, for on-road non steep downhill use I think this isnāt such an issue (For my 29+" Schlumpf that I ride for Downhill and in bike parks this is a concern and I would like to switch to an on-hub disc but that wasnāt available until just recently). As has been said, if this is an issue, I would look at the BrakeFast (although it is totally new and I have only seen the photos and diagrams from Maksym). Technically, yes, having a internal disc makes the wheel weaker, as then the wheel is asymmetrical (ok, you also have to buy 2 separate spoke lengths). But in practice this is not a problem and if it were a big problem, than basically all modern rear bicycle wheels are weak as they as really asymmetrical with a cassette. Unless youāre going for an ultra-light build with crazy custom stuff like super thin spokes or reduced spoke count, then I donāt think it should matter. I have had no problems with my internal disc on my ungeared Oracle 36.
So yes, definitely get a brake. I canāt imagine going fast in high gear without a brake! Similarly I donāt like riding my ungeared 36 fast with short cranks (110/100mm) without a brake. Of course braking-through-the-hub in high gear causes extra stress and wear, but I think for on-road use it is not such a problem.
Concerning ghost/accidental/inadvertent shifting: I have KH Spirit cranks and I have had a few ghost shifts, but I would say it is mostly an issue of practice and the right shoes. I personally have straight cranks (VCX multihole) on my fixed 36" with 125mm spacing (Nimbus Oracle). And I have Spirit cranks on my 29+ with and without Schlumpf. I find the right shoes to be key to shifting the Schlumpf: with my clunky FiveTens I can shift pretty well but when riding in normal sneakers I sometimes canāt shift on the go and have to stop or totally slow down to shift (Iām sure if I practiced then it would improve).
I think it also depends on your crank length and shoe size. With 127mm/117mm cranks and my US size 11/EU 45 shoes my foot and parts of the shoe run near the shifter but with longer 150mm cranks my foot is further away so basically canāt shift unless I actively reposition my foot.
Q-Factor: Without having lots and lots of long-distance road experience and not being a track racer, I would say the wider Q-factor is only an issue if you want to spin really high RPMs, as the width gives a little more side-to-side motion and/or you have to work a little more against the side-to-side as the Q-factor increases so a smooth high-speed spin is easier with a low Q-factor (but with the Schlumpf high RPMs is exactly what you donāt have to do). Of course this may differ for someone shorter (Iām 6ā1"/185cm tall). So I think for a Schlumpf it is a non-issue and/or just personal preference.
As to the wheel stability of in-board or out-board, as a downhill rider who really stresses my wheels, I think for on-road use any of these should be fine (not sure if this changes if you consider a really light carbon rim although generally carbon also has great lateral stability). I have had almost no wheel/hub problems with any of my inboard or outboard discs⦠actually thatās not totally true as I my first 125mm hub on my Oracle 36 wore out as the spoke eyelets pulled out of the hub, but I think it was more from basically never truing my wheel for a long time after I banged the rim a few times and then tighting the spokes up too much rather than the wheel/hub design).
As to the frame choice (I didnāt even know there was a 125mm Schlumpf hub now available): I think they are all good frames and you just need to make sure they fit the Schlumpf. The Mad4One frames are nice and the double-tab is a plus if you decide to change anything later and I would trust Marco if he says it takes a Schlumpf hub. And if you stick with the 100mm hub spacing then you can definitely use the KH Spirit cranks if you want to push your ankle out from the shifter without getting a massive total Q-factor.
Wait I just realized I maybe missed something: is there a new Schlumfp hub with a disc mount? Or are you already planning with the BrakeFast or similar mod? Because as far as I know there is no out-of-the-box capability to mount the disc directly on the Schlumpf hub. An external disc with the disc mounted on KH Spirit cranks works (but braking force goes through the hub), which is what I have on my 29 Schlumpf on a KH frame.
Oh, just a last comment and of course crank length is such a personal thing, but if you were previously riding without a brake, then just be aware that the world changes with a brake. While I think a 36 Schlumpf with 150mm cranks is fine for on-road in high gear 150 is quite long for low gear, and you could consider a bit shorter (my ungeared 36 I run mostly with 125mm cranks as I ride lots of off-road but would go down if I only rode road, although the 100s are really short so donāt like so much in the city where lots of other people are around). For my 29+ Schlumpf which I mostly use off-road I switched from 117/136mm to 127/150mm as the 136mm in high gear was a little too much for me off-road right now. But on the road the 117 in high gear are great! Which translates into effective 138mm for a 36 (my 29+ has an effective diameter of 30.5").
I think itās worse on road, as youāre likely to be going faster and braking harder in gear. The high stress/impact stuff off-road is far more likely to be in 1:1
