Huni-Rex
But do you also prefer a Huni to a 36"? I mean did you ever regret getting a Huni?
I didn’t get the huni rex because the shipping was over $200.
Between a 36er and a Huni Rex, if I had to choose to keep only one or the other, I would still choose a 36er. My biggest reasons are that it’s mechanically simpler (easier to work on) and there’s no risk of pedal strikes.
Ranking the Huni among my other unicycles though, I’d say it’s easily in my top 3. Most of my riding in general is road riding so the Huni is right up my alley. I’ve spent time on both my 36er and Huni about equally last summer.
I’ve only tried Hunirex several times. I found that its Q factor is so wide that my legs are at an unnatural angle, which might cause knee pain after long rides, though I haven’t tried riding for long distances. Besides, I found that it’s more comfortable and smoother to ride a regular 36er, and I feel safer. To ride a geared unicycle, I would need more robust protection to make myself feel comfortable.
I guess I will see when I tumble off at a good speed. From the EUC I also learned that at the start I don’t really trust the machine and don’t go so fast, but quickly you feel comfortable. Now that I can do 40 kph with it, I do wear shinguards, wristguards and fullface helmet.
But I only do wristguards when riding my 36" UW. Unicycles with a seat will always land you on your feet, and my top speed with the 36" unicycle has maybe been 18kph, but I never UPD’d at that speed.
For now I can only speculate how the Huni-Rex will feel and I just need to be a bit more patient. But Im really looking forward to trying something new
I disagree that a unicycle with a saddle will always land you on your feet. I have been on the ground enough times to prove it, including twice this year. Wrist guards saved me both times.
ok, but then you must have done some tricks or with muni done steep descents or something? With the way I ride, primarily on bike paths, the chance of landing on my bum is very very small.
This year I had a Crash during a sweeping right turn on an uphill , at speed, a turn I have made a hundred times with out fail. The other was at the tail end of a ride within 20 feet of my dismount I road up a wood ramp and where it mated up with the pavement there was a hump I wasn’t counting on and went down, with an audience. Also on my Sunday ride this week, which was a beautiful 8.5 mile fall ride I had a near UPD when I hit a hole in the path that was covered with leaves bouncing my left foot off the pedal unexpectedly, I was able to recover, reposition my foot and kept riding. They can happen on routine rides where you are riding along comfortably and confidently, most of the time you will run it out but there are times you don’t. I’m sure I’m not the only one out there crashing on a routine ride. Just as I told my audience at my one crash " it happens, not often but it does happen.
That’s just the difference between a UPD, and actually falling off.
When I fall off, it tends to be pretty catastrophic. Last time I fell off properly I cracked a rib, which I then broke by sneezing a day later. That wasn’t a fun few weeks of recovery.
That kind of thing also doesn’t happen to me often, but a fall normally results in at least a bit of missing skin.
I always land on my feet, but it I’m going fast enough, my feet land me on my face. I like going fast, so I always wear knee pads, elbow pads, gloves and a helmet when I ride my 36er.
It took me a while to adopt all the gear, but road rash is a bigger pain in the ass than wearing pads
Iā€˜m curious, did you ever need the elbow pads? I too wear them on the 36er and the G29, but so far I only needed knee pads, gloves and crash pants.
I usually go for a dive roll in a high speed crash. From the initial foot plant, I slap the ground hard with both hands to get the roll going, then roll through my right elbow to shoulder to hip, and usually to my knee too for some reason. Its generally just my right side that gets the impact, but the pads on my left side have really come in handy when there’s trees or parked cars in the way
I can see Im just a different rider. I don’t care much for speed. I guess with anything smaller than the 36, I stay below 15kph. I UPD or hop off the front when chickening out often enough, but those speeds don’t require a role. Also I hardly do tricks with my uni. Only on the Ultimate wheel do I wear wrist guards. The full protection (knee, wrist, helmet) I do wear on EUC when riding 40 kph, but even with that I ride very conservatively when it comes to bumpy sections or bends and slow down dramatically.
Different peeps, different styles.
For the Huni Rex, I may also just wear wrist guards. Btw, can it handle a thrashing? I expect in the learning period, it will land on the ground a few times.
Something else, I saw various vidz on youtube about mounting a Huni and those peeps said you shouldn’t mount too much to the front, because the wheel needs to pick up momentum first. Would this be the same as with ( I wanted to say UW 36, but most of yous haven’t ridden that), so a normal 36" at static mount?
It’s is a pity it is getting so cold and rainy and dark when I come home from work, but looking very much forward to taming the Huni.
Finally after work I found some time to try out the Huni. It is such a srrange contraption. Initially when the large Q-factor was mentioned, it didnt look like much when unpacking, but when sitting on it, it was something different.
I have a section with 40m low fencing in town, where i learned yo ride UW (which has the opposite Q-factor).
At first I just held the fence with one hand. It is important to keep the speed or you just tumble off the front.
A few times I pushed away from the fence, initially only doing half a rev but at least balancing. It takes quite some force from my non dominant foot to go for the second half rev and by then my body is too far to the front.
Lastly the sway is slower than on a unicycle of similar size, which feels very strange. On a 36ā€ you kind expect it and makes it natural.
But I should be able to ride it. Not impossible. Though freemount will also take a while
Did you grab the seat while riding? I learned by being ejected ā€œout of the blueā€ that it’s better to grab the seat (or T-bar or whatever) when riding the Schlumpf in high gear. It allows me to put so much more power to the wheel when needed to keep the balance. In my case the setup corresponded to a 43-ish inch wheel. Not sure what the Huni corresponds to.
The Huni is around 39 gear inches or so. Definitely need a bit more support riding the Huni compared to a regular uni, whether it be bracing using the saddle or a bar.
yes the pedal gives requires so much pressure that if I don’t hold the seat, I’m lifted out of it and will lose my balance.
I was wondering if having a ride on the 36" before the next training session would make it a bit easier. There I know how to balance up on the seat before taking off. But the 36" of course has a lower Q-factor which makes it easier.
:100:
Actually, I think you start to lose the balance first and are lifted because you try and apply a lot of force in order to regain the balance. Unfortunately, that doesn’t work and you get ejected.
I think riding the 36er could be beneficial to some extent, since it would help to get in the groove with a uni that reacts slower to your input and as a consequence requires you to stay within a smaller range of imbalance.
But ultimately, they are different unis and naturally ride differently. My G29 in high gear is a different beast than the 36er. More work, more ā€œintimidatingā€. But can also be more fun once I’m in the flow.
As with all of these contraptions, it takes some time before I trust it and trust myself. With the 36" UW you just have to go for it and don’t hold back out of fear. I noticed the same with the Huni. The speed helps maintain balance, but speed also makes you crash harder.
And I noticed the same with my Electric Unicycle. People riding 40kph while I didn’t dare go faster than 20kph. Nowadays I am so accustomed to the feeling, I can safely hit the 40kph.
That’s - among other things - one reason why I bearly rode in high gear, this year. 36er and G29 in high gear for me means wearing all sorts of protetors, which kinda sucks. That’s why I tend to use the non geared 29er instead. It’s fast enough for most of my needs, I’m more used to it and can ride it safer. So chances of having a fall are reasonably low while chances of walking mostly uninjured away from a fall are reasonably high.
