What tool is used to change cranks and where can I get one?
A short how-to would be appreciated. Thank you!
Thanks. Does that work for non-ISIS?
Ah, I guess with the crank puller and adapter you can do both?
Are Coker The Big One cranks splined?
No, I have a Coker Big One and it’s Square Tapered. The KH36 and a few Nimbus 36ers are ISIS.
Yep - I use a square taper crank puller with an adapter for ISIS (and Octalink )
OK, I’ll just need the puller then since both of my unis are not ISIS.
Thanks guys.
