I’ve been wanting to paint my unicycle for a little while now, problem is I don’t know how to do that. If anyone has painted their own unicycle, I would love to hear your process & know what paint you used!
Lots of threads on this already, but I am interested as well
What are your plans for colors or themes?
Honestly, I’m not sure! I wanted to do a sunset gradient (yellow, orange, pink), but I don’t know how much harder that would be than just painting it a plain color.
The quick and dirty way of painting a unicycle is to just disassemble it, sand it down with fine sandpaper and give it a few coats with a can of spray paint. Auto parts stores are a good place to find a wide selection of spray paint, much better than hardware stores. Doing it this way is cheap and easy, but not very durable.
If you want it to last you’re going to want to apply a clear coat afterward and use a real automotive grade paint, not the touch up spray cans.
+1 to what others have said. Having painted my unis several times now best to sand down as much as you can, clean off the dust with a clean clothes, get a really good direct to metal primer (I use grey tremclad spray), apply your colour in one or 2 coats if you’re doing a light colour you’ll want a few more coats same with a vivid colour and get a clear coat to go over top, when it’s dry to the touch you’ll spray on your next layer as per the instructions
Then don’t touch the uni for a week and give time to properly harden
Thank you guys, I’ll keep all this in mind when painting my unicycle! When I paint it, I’ll post a picture here (although that might not be for a while since I’m an expert procrastinator)
What is your frame made of? Surface prep is different for aluminium and steel.
It’s steel
