Hi, currently I have bent 2 sets of crank arms, thats 4 cranks. My unicycle has about a 25 degree bent. That is my hub bent im pretty sure.(see my avatar for refrence) Im guessing that I should buy some decent cranks.(i.e. a set of kris holm cranks) These cranks are some generic cranks (with hub and rim) off of my first unicycle. yeah… I may need help with this one… Any way that I can absorb shock to keep my bent cranks from snapping? Thanks for help!
any splined cranks/axle that fits the cranks will do.
this happens to the best of us, until we get good(teeeeheeeehee…Just kidding)
qu-ax
Kris holm
torker(wtf)
koxx one
one of the above axle(hub)/cranksets, splined… never break anything again.
that said, i have done over a 6’ drop on a CX wheelset and it is true as ever. You could land better, but you have to learn that, you will get it eventually.
Ok, thanks, I was thinking about getting splinned cranks, or atleast get a new unicycle. My current one is a freestyle unicycle that i modded out into a trial one. Im just gona buy a kh 2007 trials/street uni.
considering im pretty novice, except for landing like 5ft drops, I really have no abilities at tricks and knowledge of good stuff for unicycles. I also ride seat in, which makes my landings probably worse
but in the end, im kinda good.
