I’ve ridden two winters with studded 29" hatchet! I really liked it. This would be my third if someone had not stolen my unicycle, and I was really looking forward to riding it!
The first winter I used an “icespiker pro 29x2.25” tire, they work, but they are stubborn to ride straight, the unicycle wanted to turn to either left or right, so I was riding the unicycle slightly tilted to go straight forward. The second winter I bought a “Suomi Tyres PIIkkisika W408 TLR 70-622 (29x2.8”)" after reading a comment about it for the 26" unicycle, and it was like night and day for winter riding. I can really recommend those tires!
But in general I would say injury wise is low (if you don’t ride outside your comfort zone). I haven’t had any accident with either one of the studded tire, maybe one small time when my pants was caught on a spike and made a small hole, but nothing more serious. Every time I’ve fallen off, it has also been the tire either sliding to the side in an “ice track” or the tire getting stuck in snow so had to dismount in front of the bike.
But in general I would keep pants that are closer to the legs so they don’t get stuck on the spikes, and keep sturdy boots so you can land safely when accidentally dismounting.
Nooope. You‘d have to be really unfortunate for this to happen …except maybe for scratching your fingers when handling the uni. But when you ride and UPD it’s usually when the wheel gets caught and stops while you keep on moving. That happened to me a few times when riding down a sledding trail. Or you UPD / fall to the back while sending the uni to the front. In both cases you‘re not near the tyre.
What‘s more likely to happen is that the knees touch the tyre while doing sharp turns when riding. You know best whether that is an issue with your riding or not. Happens every now and then for me, but I don‘t remember any torn trousers or sore knees, so it was not too wild, I guess. Have to add that I often/usually wear knee pads when riding in the snow - that could have helped.
I say just go for it. I‘m very positive it‘ll change your winterly unicycle experience - certainly did for me!
By the way, which tyre make did you get with our Hatchet? Don‘t forget to share your experience with it, should you indeed decide to use it.
That’s very reassuring. I’m really looking forward to trying out the studded tire, and snow/ice muni in general. I’m thinking the winter season could transform the trails I’m familiar with into an entirely new set of challenges and fun.
I’ll let you know how it goes! Probably still a couple months away though.
The studded tire I’ve got for it is the 45NRTH Wrathlorde 26 x 4.2. I’m currently rolling on the Maxxis Minion FBR 26 x 4.8. I’ve got nothing to compare it to, but I’m liking it a lot
So I don’t have a Hatchet . But I do have an Oregon .
Had a Schwalbe Al Mighty 26x4.8 last winter and a 26x4.0 45NRTH Dillinger 5 the winter before. They both work well for me, though I think the Al Mighty has a bit more grip on snow. So that’s what I want to use for the coming winter. I have a Surly Marge Light rim (65mm wide) on my Oregon, by the way. Grip on snow and flotation should even be better with a wider rim. On ice you can basically do whatever you want without fearing to skid.
