Do you have a homemade unicycle or parts ? Frames, hubs, cranks, seat ? Show photo and write your unicycle or parts, you help other in build unicycle
I build a begginer unicycle 24" I use a old bicycle wheel with hub and new simple bicycle cranks 165-170mm. I must alter thread in one cranks to pedal, (two left cranks bicycle). Frame and hub J made with my friend, seat and seat post i buy- qu-ax luxus.
Photos
What are you thinking about my uni ?
I thinking to alter this unicycle to 28" in next time
I ābuiltedā a frame yesterday. Itās a Custom LongNeck! itās built from a Nimbus 1 frame(22.2 seat post) and the neck of a scooter witch is aluminum and 25.4 seat post! here it isā¦
The whole set up.
The Crown.
Do you have a clamp for that or something? That doesnāt look right, you put the scooter frame over the original frame to make it a longneck? Iām confused
I just throwed it on the ground, I have a clamp for it but itās too big so I donāt ride with it and yeah, itās just to have a longneck, but I still like more my KH 2005 frame than this one.
Cool, you have a piece on either side? I wonder how that will actually perform, depends on the weld and stuff I guess, and I donāt think youād hit the edge at all.
its made from regular steel
its not for myself but for a friend who is tired of snapping his seatpost
couple of regular seatpost
and i think he is down to his 3 alu seatpost with the reininforcment of qu-ax
the alu seatpost of qu-ax tend to snap off just under the reininforcment weld
if i have some spare time i will make a seatpost out of alu just like qu-ax but leaving some more alu at the part just under the reininforcment
offcourse there will always be a next weak spot to break something:D
ok it is not a uni cycle or part but its funn to ride i didnt bolt or weld anything to my nimbus 24 i made a frame tht acts like a seatpost and bolts into the frame just slides in and tightens with the seatclamp i had to make a custom bearing holder my only tools were arc welder and angle ginder
