ok so im learning to weel walk and i can go mabee 10 feet but whenevr i lean too far back a put my feet down i keep slicing them on the (plastic) pedals or my foot gets wedged between the crank and tire and i slam to the grond or i get going too fast and fall. So any suggestions on anything or tips too help me lern
You could try practicing against a wall, and just ditching the cycle entirely if you are past the point of no return (please forgive the cliche) in any direction. I can freemount to the wheel and start walking, and I learned next to something (walls, sheds, trucks/whatever). You could also get some shin guards that have padding in the back, but I’ve never used pads. Flexible shoes are good, and enough grip to not slip off of the wheel is also helpful. I walk in converse, which don’t have grip.
I tried not to learn against some thing cause then you learn to lean to one side or some thing…when your feet start to slide down just throw your feet out to the side so the uni lands under you or just lean off the side. Try going as slow as you can when learning…thats what i did and now i can go forever. (not really but close to it) When you start to lean forward just don’t wall the wheel and lean back
