Have you seen this 36er crash?
The unicyclist comes into view riding at a good pace and then makes a nice, smooth turn. He is not a novice and seems like a skilled rider. After he comes out of the turn, he straightens up and continues down the pavement. Then you can detect an ever-so-slight wobble, but it kind of just looks like the normal, small bit of wobble you can sometimes get on a 36er (which can be less or more pronounced based on the type of cranks you have and your pedaling technique), so it seemed like no big deal. Then, fairly suddenly, significant wheel wobble occurs and the rider is thrown off his 36er. Leading up to the major wobbles and ensuing UPD, I didn’t see anything about the unicyclist’s riding that would have made me think that a crash was imminent. Though you can’t see the pavement all that well near the crash location, from what can be observed, it seems to look ok, but maybe there was a pot hole or some other abnormality. I don’t think I have ever seen an experienced 36er rider get severe wobbles out of nowhere. As such, I would be most interested in hearing your analysis of this UPD. What do you think caused it? And If the rider is on this forum, it would be great to hear your account of what happened!
I’m still not sure myself after going back and forth a few times frame-by-frame (for those that don’t know how, pause the video and use the . and , keys to do so).
I don’t think the pavement is an issue.
Slowing down the video I think the rider has come out the corner and started to accelerate hence the sinusoidal motion. My best guess is that the rider has pushed his left foot down faster than he can force the wheel to accelerate on the final stroke causing the wheel to kick out to the side.
It seems he‘s lifted out of the seat just before the fatal wobble. But I can‘t see why. Doesn‘t look like he‘s leaning too much forward to me …which - if he was - could explain why he‘s lifted out of the saddle (Happened to me on one of my first Schlumpf rides).
I‘m pretty sure though that the big wobble is a result of him losing the firm contact to the seat. Plus he apparently didn’t hold the handle bar. Maybe that could‘ve helped in regaining control.
Hm, maybe his shoe lace got caught? His foot is not attached to the pedal as he falls, though, so the lace would have to be torn apart before or at the beginning of the fall.
I always get more wobble without at least one hand on the handlebar. Looks like he just pushed it to the breaking point.
Here is another video with a similar crash:
The comment from the rider is pasted here:
Riding a 36" Nimbus Unicycle at approximately 10 M.P.H. and lose control, have no idea what happened???
I was riding then I wasn’t???
Apparently, he is as mystified as we are. I think that once the wobble started, he was launched upward off the saddle, which made him lose control since he did not have a grasp of the saddle. Once his butt lost contact with the saddle, he only had two points of contact…his feet on the pedals. Prior to that, I’m thinking that his butt and inner thighs were keeping the saddle under control.
I see it exactly the same way. Just not sure what caused him to lose contact in the first place.
Isn’t a wobble less prone to happen on the bigger wheels? I’ve had it happen a few times with the 26er and 29er, but always because the road had a dip and my mind had wandered far away from unicycling. I never go so fast I can’t run out of it.
I think the first video is very extreme.
I thought that myself, being the victim of a shoelace crash. My shoelace did rip in half thankfully but I did fly forward in a similar manner. Somebody out there should know this guy or maybe the rider will reach out and give a play by play. Any way we have all been there before crashing with an audience, maybe not by a camera though.
yeah a camera will make you feel humiliated again and again :smiley:
My guess: his left foot slipped on the downward motion.
Not completely off the pedal, just the half slip towards the front, possibly stopping with heel on pedal. His reflex response was stiffening of muscles in general, so the right leg in the back gave more resistance to the upward motion. This caused the wobble, which begins with a turn to the right. The overdosed pressure of the right leg in back also slowed down the unicycle when the rider didn’t anticipate, so started to loose balance towards the front. Since the left foot didn’t slip off all the way, there is one more revolution, but out of tune, he couldn’t catch the imbalance and then goes down.
It looks like his left foot briefly stays with the pedal, as he starts his fall? Could his shoe lace have caught and then yanked loose? Just a guess.
I had one fall I’m still trying to figure out. The wheel got turned 90 degrees to the right. I landed on my left hip (lower body turned 90 degrees with the uni), but came down almost equally on both hands. So, my upper body was straight. Didn’t see anything on the road that could cause a crash.
Yeah it hurts my laugh-muscles. It is quite of a blooper. It gets really funny when you see it a lot. :stuck_out_tongue:
Now at 50 I feel my knees much more. When normal unicycling, I hardly feel them though. It is with Ultimate Wheel and also just when walking that they hurt. Even when hopping the tire catches enough of my weight not to make it hurt. As long as I don’t do too fancy things it shouldn’t be a problem to still ride in 15-20 years. I mostly prefer the 29” but occasionally take the 36” for a spin. It is just not so good jumping off the front for my knees, if I fail to step off behind the uni.
I saw this possibility, too. But thinking about it again, it’s probably something else, since the rider says he has no idea what happened. If it was the shoe lace he would know, wouldn‘t he?
It’s good to see an explanation from the rider. His quote of “ I was riding then I wasn’t” is something we all can relate to. My one and only bad upd of the year happened with an audience. I was trucking along feeling very comfortable and pedaling a smooth and consistent pace when all of a sudden I was on the ground . A concerned walker asked if I was ok and I replied yes I’m ok , it happens, not to often but it happens.
Thanks for all the feedback! There were lots of good theories put forth, however as has been pointed out, the rider himself doesn’t know what caused his crash, so I agree that seems to rule out an untied shoelace (or a pavement issue) as the culprit. Having now viewed the footage several times at 0.25 speed, I agree with davejh’s comment:
I concur that it looks like the rider pushed down hard with his left leg (seemingly in order to stand up off the seat) and in so doing caused the wheel to kick out to the left. What initially looked like a wobble now at slower speed playback looks more like the wheel simply yawed left (while the rider wasn’t stable on the seat) due to the rider’s control inputs, which bucked him off his ride.
Another vote for the unexpected shadow bump that was never there.
The vote was there too… really!
I think @Wheelou also has a point. The riders bottom definitely lifts on the last stroke which would not help with balance and stability. I’d refine to suggest that the rider partially stood up by putting their left foot down too hard/fast.
A more controlled version of this type of taking weight out of the saddle is a good way of going from pavement to road via a drop kerb. You can create an brief instability in the direction of the unicycle while maintaining direction of balance and use it to do a 1-2 foot sideways motion within a short distance without dropping much speed.
Wow, you do that? I don’t think I could; I usually just continue spinning normally. Or, if I need to do strong corrections I twist from the hip.
Also, I‘m still puzzled how fast of a wobbling movement the uni in the vid is doing, considering it‘s such a large wheel. So far I‘ve only seen this sort of behaviour from 36ers in videos of people doing muni with their Cokers.
