before i go and remove my profile cranks i’ll try an cut a slot in the cd and stick it on, technicaly i only need my grab side protected (lefthand back side). so i might end up cutting a bigger slot out and then using zipties to keep it from getting in the way of anything.
> i made a grab gaurd out of a cd,
> have a look…
> its just a prototype but it might inspire somthing better when i find
> out whats wrong with it.
> if it works it’ll save me tightening up my spokes so often.
> http://www.unicyclist.com/gallery/album62
> i havent tried it yet because its 3:14 am and the streets are full of
> nutcases
> expect a report over the weekend.
> evilewan - death or glory
> evilewan
> evilewan’s Profile: http://www.unicyclist.com/profile/1047
> View this thread: http://www.unicyclist.com/thread/20622
yes, i bend my spokes i havent broken a wheelset yet but i do have to tighten my spokes fairly often.
i do loads of grabs and a couple of times i’ve whacked spokes trying to grab onto less than ideal surfaces and had to re-true my wheel, hopefully if i find a solution i won’t need to worry so much about my very expensive hub,
grabbing onto nice ordinary wooden bences doesent bend your spokes, however grabbing onto bad surfaces, things get a bit more stressfull on the unicycle
remember that the only part of the profile hub that is not covered by a lifetime warranty is the hub shell, this is the part that takes the stress when the spokes hit somtthing.apart from the spokes themselves, which get bent and start needing to be tightened more often
my experiments with grind gaurds come from the my experience of things getting bent and scuffed and then having to be fixed
i’ve spoken to george from g-sport bmx and i’m going to get a g.l.a.n.d.
(Grinds Lovely Anti-Nagging Device.)
p.s. theres some more pictures in my galery, i tried out the cd gaurd and as a prototype it worked perfectly,
that is, it broke.
at least i know that the spokes could benifit from a bit of protection.
as well as protecting my spokes and hub i’ve been thinking about grinding with the spokes like bmx freestylers do. this would enable me to do it with out worrying so much about my expensive hub flanges.
at £10 the g-sport g.l.a.n.d. is fairly cheep.
