This message is in MIME format. Since your mail reader does not understand this
format, some or all of this message may not be legible.
------_=_NextPart_000_01BE0C2E.52438C95 Content-Type: text/plain;
charset=“iso-8859-1”
Muni enthusiasts,
Below is my list of MUni terminology. Some of the expressions are serious and
some are for fun. Some comes from mountain biking or other sports. What’s
missing? What special words or expressions do you use where you ride? What would
be fun to add? I’d like to add all the good ones. In some cases, the name of a
term’s originator appears in parenthesis.
GLOSSARY OF MOUNTAIN UNICYCLING TERMINOLOGY:
Adjusting Handlebars: An expression used for taking a restroom break along the
trail: “Excuse me, I have to adjust my handlebars” (Bymaster).
Adjusting deraileur: Female version of adjusting handlebars. So named because it
is more complex and less likely to happen.
Bonking: Too much redlining or dehydration.
Breaking point: The spot on the trail where your unicycle breaks and you have to
walk back. Usually at the furthest point from the car. Also known as turnaround
point and walk-home point (Foss).
Butt plant: Hurts, usually happens when someone is looking and photographing.
Calf Tracks: Marks on the back of your leg from errant pedals (Geoff Faraghan).
Cliffside retrieval: Having to climb down off the trail to retrieve a dropped
unicycle. Sometimes a rope is needed.
Catching air: Riding over any obstacle that leaves you momentarily airborne.
Dabbing: Dismounting or putting a foot down.
Dead spot: When the cranks are vertical and you have no power.
Doing a Brett: Riding up ahead, doubling back, riding up ahead of the rest of
the group. Named for Brett (Bloodman) Bymaster, who’s got too much energy to
ride with a group of normal riders.
Doing an Andy: Tasting the local flora, fauna or dirt. Named for Californian
Andy Jennings, who has been known to not only sample water and plants, but to
(purposely) taste the trail dirt!
Doubletrack: Trails that should be ridden by two or more unicycles.
Eating It/Eating the Trail: What happens when you try to pedal past your balance
point and don’t dismount in time.
Fall line: Direct line down or up an obstacle or hill.
Flail arm: The arm you wave around to keep your balance while holding the seat
with the other hand. Also known as swing arm.
Flailing: Wild arm movements used to keep the cycle on the trail, often used
when riding along the edge of cliffs.
Getting forward: A particularly important concept in MTU, it means getting way
out front of the wheel to ride up and over obstacles and steep slopes (Peck).
Getting launched: There are many varieties involved here - clean ones, crooked
ones, face first, knee first,etc. (Peck).
Gnarly: Any terrain that requires hopping or pecking.
Head dab: Polite name for a faceplant.
Hip thrust: Used to flick the unicycle to a new pedal level position (Peck).
Hovering: Temporary zero rolling while weight or mind is collected to survey
for, or make a new move. Also known as Twisting. Also means the same as Idling
or Rocking in non-MUni terminology.
Invisible Bump: An excuse for falling off, usually told to fellow riders. Also
known by UK riders like Mini Mansell as “Hitting a big lump of nothing”. Also
known as “Cosmic rays” by Santa Cruz riders Lloyd Tabb and Bruce Bundy.
Jammed: Like stalling but more abrupt (Peck).
Micro-focus: Seeing and responding to what is immediately going under the
wheel (Peck).
Pecking: Using hopping movements to get over obstacles. Can be several hops, or
just one. Named for George Peck, master of rough terrain.
Pedal strike: Very bad. Instantly causes lots of air between saddle and rider’s
rear (Peck).
Power position: When the cranks are horizontal.
Really stupid: Not wearing pads or helmet after you’ve already hurt yourself.
Redlining: Reaching or passing one’s anaerobic zone, usually while
riding uphill.
Rolling the pedal: When a bump causes the pedal to flip under your foot. With
luck your foot stays on and you can correct your foot position without
dabbing (Foss).
Shindentations: Marks on the fronts of your legs from errant pedals or other
obstacles (Nathan Hoover).
Shooting the pedal: Foot tripping off the pedal, similar to Rolling the pedal
but quicker (Peck).
Shrake: The sound made by unseen tree branches scraping the top of your helmet.
Also “Ouch”, when the branches poke through the helmet’s air holes, or if you
aren’t wearing one (Foss).
Side dabbing: Using a tree, rock or other trailside obstacle for support with
hands, arms, elbows or feet.
Singletrack: Trails that should be ridden by unicycle.
Snake bite: Double hole in tube caused by low tire pressure and edge impact.
Spinout: When the tire looses traction and the wheel spins in place.
Stalling out: Getting stuck at an obstacle with pedals in the dead spot (Peck).
Stupid: Not wearing pads or helmet appropriate for the activity.
Style Points: Awarded a rider for great bodily, or unicycle motions in a
dismount (Foss).
Swing arm: The arm you wave around to keep your balance while holding the seat
with the other hand. Also known as swing arm (Foss).
Tire poppers: Sharp-edged rocks that can do you-know-what (Foss).
Trail Diving: To fit this description the rider generally has to land on the
trail, face down.
Un-Tool: The one and only tool you needed to keep from walking, and you
didn’t bring it.
Unicycle bowling: When the unicycle catches air or rolls over multiple times
while falling down the hill (with or without rider).
Unweighting: Very important for getting the pedal to a new power position. As in
a curb…you flick your weight forward and up, unweighting the cycle as it lifts
up the curb (Peck).
Yee Ha!: A sound uttered by North American unicyclists when riding on really
fun trails, usually while going downhill. Synonyms: Wheee hoo, whooo, whooee,
whee, etc.
Yeeeeah!: A throaty sound uttered by North American unicyclists upon reaching
the top of a very difficult descent, or after a stretch of nearly impossible
trail. See above for variations.
Zoom: Getting speed up for an obstacle.
Please send your additions or comments.
Stay on top,
John Foss, the Uni-Cyclone http://www.calweb.com/~unifoss/
Coming soon, unicycling.com!
------_=_NextPart_000_01BE0C2E.52438C95 Content-Type: application/ms-tnef
Content-Transfer-Encoding: base64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 Y7-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------_=_NextPart_000_01BE0C2E.52438C95–
