[FOR SALE] [EU] Kris Holm KH29 Frame v.2010
Hi all! Got this Kris Holm KH29 Frame, 2010 version for sale. Would let it go for EUR 110. Got a better offer? Let me know via PM please.
The frame has been spray painted black matte. Seat clump included. There is a small blemish in the paint caused by storage - visible in the pic.
I’m willing to ship globally if you’re willing to cover the shipping :wink: Preferably within EU, though.
Please, mind that this is the model that only accepts the spirit cranks for the disc break and a set of standard Magura breaks.
Hi @paweloyama,
Nice frame and could be the missing link I have been looking for switching between 2 frames :upside_down_face:
However, I was not able to find the clearance mentioned in the original product announcement, so do you know if it can fit a Surly Dirt Wizard (29x3.0)?
Thanks :slight_smile:
Thanks for the interest, @Siddhartha_Valmont! :slight_smile:
As far as I know the 29×2.5 is the practical maximum.
29×3.0 fits only very tightly depending on rim/tire and tire pressure, with little mud clearance. So I’m afraid it’s not the frame you’re after.
Sauce:
Are you going to UNICON? Can you bring the frame? I want to buy it. I live in Norway, so not EU…
Hi, @idleboy! Thanks for the interest! I unfortunately won’t be coming to Unicon, but I just PMed you :wink:
I know I am late and maybe this frame is taken but yesterday I did some simple measurements of the frames I have that don’t or barely fit a 29x3.0 tire.
@paweloyama : do you mind measuring your frame height from the top of the bearing slot to the top of the crown ? And if it is 37cm or more, can you please also measure the inner side-to-side width right under the crown corner reinforcements (or next to the top of the magura mounts if it is easier) ?
This should help confirm that whatever tire I (or anybody else) want to put in fits or not (for the height measurement, it should be at least 1cm more than the same measurement taken on the wheel outside a frame with the desired tire mounted).
Thanks :grinning_face:
@Siddhartha_Valmont That is a great idea!! Thank you! I’ll be back home on the 14.07.2026 and will make sure to take the measurements and post them as soon as possible. The frame’s still available btw :wink:
  • from the top of the bearing slot to the top of the crown: 38,6cm (measured on the inside of the frame as in the pic below)
  • side-to-side width right under the crown corner reinforcements: 8,25cm
Bump.
Bump :wink:
