Is the correct position for the foot on a unicycle where the ball is on the pedal?
I am learning to ride and seem to have trouble. I start out with the pedals basically horizontally but I seem to get trapped (go no more) when the revolution goes around to where the pedals are vertical. I see to stop and lose the unicycle.
When I was learning to ride, I had that problem at first; it turned out
my seat was too high. Don’t know if its a posibility in your case, but if
so, have someone whatch you (attempt to ride) and tell you how extended
your leg is when the pedal is vertical. I found that I couldn’t keep
pedaling if my leg was fully extended; my knee had to be slightly bent.
Hope that helps.
> Is the correct position for the foot on a unicycle where the ball is on > the pedal? > > I am learning to ride and seem to have trouble. I start out with the > pedals basically horizontally but I seem to get trapped (go no more) > when the revolution goes around to where the pedals are vertical. I see > to stop and lose the unicycle. > > Is this an experienc or awareness thing? > > Derek > > > > > – > Posted via the Unicyclist Community - http://unicyclist.com/forums
