I’m looking to sell my trusty ol’ 36er. It’s a good ride, but I have a bike now so this thing won’t be feeling much love around here.
I bought the Titan from UDC in April last year, and over time have added a thing or two:
-Nimbus Titan Frame
-Stealth2 Rim
-Nightrider Tire
-Both 114 and 150mm Nimbus Venture Cranks (the 114’s are Venture II’s and the 150’s are Venture’s)
-UDC Super wide 125mm hub (cotterless)
-Nimbus Shadow Handle set with aero bars (will include the original bar ends with animal grips)
-DMR V8 pedals (will include original United pedals and extra grease for the DMR’s)
-KH street saddle (flattened)
-Tubeless setup (Gorilla tape and 949 racing valve stem, I’ll include some extra sealant if you want along with 2 tubes if that’s your flavor)
-Bell Cycle Computer (has odomoter, speedometer, max speed, avg. speed, time, riding time)
-Sunlite sidepull brake (UDC version, set up with a shifter)
-Handle bar bag on rear Shadow mount for carrying gear. Works great.
Like I said, this is a great ride and hasn’t given me any problems. The computer has 162 miles on it, I probably had 200 on it before I added the computer.
The tire is set up tubeless which, even though it’s a bit painstaking, it’s nice to not worry about punctures and save some weight. Lots of tread life left.
I have two different crank length’s, and the Aero bars are nice for laying down and taking a nap on the flats.
The seat has been flattened and is very comfortable. I like the Street saddles for distance riding and Muni.
I set the brake up with a shifter lever so you can lock the brake on longer down hills. I’ll include the original brake lever too.
One thing I gotta point out, is that this is the frame that I bent to fit the 100mm Drift Trike hub. There are some small indentations on the inside of the frame legs for this. These have no significant effect on strength. The frame was bent back to fit the 125mm hub again.
If you are interested I’ll throw in the Drift hub and spokes to lace the wheel for another 80 bucks.
Brand new, this is a $900 setup. I’m looking for $650 but am open to reasonable offers.
I am not going to ship this.
This is the frame bent to fit the 100mm hub. It’s been bent back.
