The Vee Rubber tires are heavy, but they ride well and they are inexpensive. If the devist8er were as light as a newer Larry, it’d be my go to fat tire.
I have a 26 x 3.8 and a 29 x3 Knard on order in a folding bead, but since the folding Knard in all sizes is still not available, it’s gonna be a couple weeks before any reviews are forthcoming.
I liked the Larry okay, but I think there are some better tires available now.
Avoid anything with a wire bead, they are much heavier construction, though they are less expensive.
All the Surly and 45North tires run on similar casings, so you should pick the tire based on the tread pattern you prefer and the lightest weight casing you can afford.
Deeper/taller knobbies are not always better.
The only reason I’d skip the ultralight casing is if you ride on a lot of sharp edged rocks.
The absolute beefiest casing is the Deivst8er.
