Difficulty going between unicycles?
A few months ago, I made a post about how it feels like my 29" unicycle pulls to the left:
A problem that I’ve now faced is difficulty adjusting when going between my 29" and 24". Let me explain further:
When I first started riding the 29" one, it felt like it was pulling to the left and I had to fight it to keep it straight. Eventually I seemed to adjust and the problem seemed to go away.
But now when I ride my 24" (or 20"), it feels like it’s pulling to the right! Even though it felt straight before. I have to fight to keep the 24" and 20" left.
Of course, I then adjust to this and the 29" again feels weird like it’s pulling left :sweat_smile:
It’s like my own internal sense of centre balance becomes biased after riding either the 24" or 29". It don’t know if it’s me or if the unicycles do indeed have a slight left/right side bias.
Does this makes sense and has anyone else ever experienced anything similar?
Does the same occur for you if you ride other 24in or 29in unicycles?
My riding bias is going between my freewheel and fixed unis. After riding exclusively freewheel for many months fixed axles were awkward. I could ride but would periodically, without thinking, and unintentionally go into coast mode and either UPD or nearly so. “Oh. Right. Fixed axle, stupid. No coasting.” That usually took me 30mins to an hour of riding to ‘fix’ and stop automatically trying. Afterwards it was just fine. Then going back to freewheeling was awkward until I was again acclimated to it. It also takes me a little time to swap between various fixed axle sizes but less than a freewheel.
Keep riding. IMO the more you develop riding skills the less of an issue you’ll experience. That has been my overall experience.
Ouch, that sounds painful. I hear that some fixed gear (and penny farthing) riders have made that same mistake too!
Well done on riding a freewheel uni though. I’ve heard that they’re really difficult to ride.
Don’t sell yourself short (yet).
Suggestion: try to ride your 29er until you are comfortable. Then swap the 29er wheel for your 24, adjust the saddle height and try to ride for a few minutes. If the problem is you sense of balance, it will feel off as usual. However, if it has to do with some differences with the saddle/cranks/frame/whatever, it should feel natural (apart from the wheelsize/torque difference).
Anecdote: I had a coworker that was riding an old cheap 20in uni with a bent axle. He was riding around without problem. However, when I had him try my 20in uni with a straight-and-true hub, he was struggling like the parking lot was a boat at sea.
Until your balance develop enough to compensate, it is normal to be thrown off by things (and saddles developing a twist in the foam can be a challenge for new riders).
I always keep the same distance between the pedal and the saddle. Whether I’m riding the 24-inch unicycle or the 29-inch unicycle, it works quite well for me.
One thing I noticed is the bigger wheels always seem to feel better. Smoother, less twitchy, go farther with less effort, etc. That feeling of appreciating the bigger wheel is strongest after riding a smaller one then going bigger again. The height is the one thing that doesn’t though, at first when going back after focusing more on smaller ones, that feels a little intimidating. I have been almost exclusively using my 20 for a while because I have been focused on learning to idle ( I can idle now! Finally!), then trying to get better at it after figuring it out.
Geez the 27.5 seems so tall now even though it is/was my favorite! I Can’t idle it yet. I can my 24, but not nearly as well as the 20.
The more I rotate sizes, the less an issue it is moving between them though. It used to be a lot easier when I did that more, but now feels like i “regressed” from too much 20 time lately and the big one feels almost as awkward as when I first got it.
I know my 27.5 will feel best again soon after riding it more. I keep wondering if I will like a 29er even more…
What I have found is that unicycling is a journey and dialing in your ride takes some time and sometimes money. Getting the right tire and pressure, the right saddle as well hight and angle, the right crank length and the right pedals. This is all trial and error but when you get it all right you will know it.
switching between wheel sizes definitely can be challenging. I have a place where I train several days a week and I like to take several different unicycles with me and play around, mounting, idling, slaloming, stalling and hopping on all of them before I settle into my main ride. It will help you to improve and keep your skills sharp.
Remember when seeking advice online, if you ask a question you will get a lot of different responses so it is difficult to filter out what is right for you. Some responses will be good advice, some will be bad advise and sometimes what works for others will just not work for you.
You just can’t tell someone how to ride a unicycle, or how to fix a problem in your riding in a forum post, this is your journey and figuring it out is part of the fun and the challenge. When everything finally clicks your riding will become a great joy and not a struggle and will bring you loads of pride in your accomplishments.
I’ve been jumping between 26" and 36" fairly often lately, so going from one to the other there’s very little need to adjust to the size difference being I’m used to it. It also probably helps that they’re both ridden in similar conditions, are running the same crank length (125mm), and I have the tire pressures dialed on both.
At least in my experience, spending time on different wheel sizes may help decrease the time it takes to get adjusted to the feel of a particular uni.
I don’t have the same Cranklength, I ride 7 different Cranklength on 10 Unis.
Much like you I ride 125 on everything but my 32 which I ridee 138’s. I keep saying I’m going to move down to 125 but have yet to make that leap. I also use the same pedals on all of mine.
I have a ‘rule’ that I don’t use the same set-up more than 3 days in a row, and I ride at least 3 different set-ups each week. Partly this is to justify having so many unicycles :rofl: but also I think it helps to keep me comfortable jumping on any uni and riding.
Oracle 24 with 2.1" road tyre and 127mm cranks,
Oracle 27.5 with 3" tyre and 137mm cranks,
Nimbus 29 with 2.5" tyre and 110mm cranks,
Oracle 29 with 3.25" tyre and 150mm cranks
Oracle 36 with 2.25" tyre and 127mm cranks.
I’d also suggest checking as best you can that everything is straight, if a uni is pulling so much that it affects your riding on other wheels it sounds like something is out of alignment. Assuming you are on the same terrain therefore road camber isn’t different? But i guess that’s been suggested in your other thread too!
I expected the cranks to be shorter on smaller wheels, as a general rule (except for the muni). But I see a 24" with longer cranks (AND a narrower tyre) than a 29". Is this for sentimental reasons - “I learned it on this 3 decades ago and I leave it like it is” - or is it to stay fit by and at using different setups?
Seems to me that one of your unis is crooked. In your other thread someone suggested to put washers under one side of the seat to try and compensate the asymmetry. Did you try this out? If not, I strongly suggest you do; and if they suddenly feel more similar or even equal you know you’re on the right track.
Well, except for MUni, except for Team Sports, except for GUni, except for Track, except for Urban, except for Freestyle… Oh… we excepted everything but Road, right?
24x2.1 @127 is good for Team Sports, possible for Track, and could be used for Urban too.
29x2.5 @110 can be a good XC or commuter.
Etc, etc.
Nehh, Im one of those guys… 150mm on 26" and up. Makes rolling feel more or less the same. Only my two 24" uni’s have stock 125mm cranks. Possibly the same for the trials and 20" freestyle, but I hardly ride the 20" freestyle. Crank length is very subjective from person to person.
I didn’t respond to this, sorry. To answer your question, I don’t actually have any other unicycles the same size. I guess the one way to settle whether it’s me or the unicycle would be if I had another 29" to compare or if I had a friend who could ride the unicycle too. I don’t know anyone else who can ride though unfortunately.
Each size does have it’s own feel though. I find that when I’m well balanced, I can put my weight into the seat and it doesn’t take much energy to pedal. I think I will try to more regularly practice each wheel size.
I don’t have a dedicated IUF unicycle and was competing at Unicon so had to set up my 24 to meet the requirements - cranks no shorter than 125mm, but since it’s an old frame i have spirit cranks for external brake hence 127mm, and the smooth 24x2.1" tyre just fits the maximum diameter limit of 618mm.
The 29x2.5 has a maxxis hookworm, a smooth road tyre, and again it’s an older frame so using spirit cranks. 110mm is the shortest available.
The 36 i may end up going shorter on but again, 110mm is the shortest spirits go, so i might need to replace the hub if I want shorter cranks.
27.5 and 29 oracles are both for muni so I like the longer cranks for control.
Thanks for taking the time to answer.
Wow, that’s a seriously advanced setup. I have 140s on my 36er and no plans to go shorter (ok, partly because I wouldn’t be able to ride some steep sections in my neighbourhood).
I just wanted to say thanks for all the great suggestions here folks. I’m going to experiment with a few different things and see what works.
