I love mine! My friend used it to clock his max speed on a coker-14.8 mph. That’s with 175mm cranks, so not bad!
I got up to 10.5 on one of the super hairy, rutted downhills, fun stuff.
I haven’t taken it out on the flat yet to verify what I had previously said was my assumed max speed. I’ll have to do that today, and let everyone know how much of a liar I am.
I am looking for a cyclocomputer to determine average and peak RPM for some sprints.
It wont be on a unicycle with handlebars so it needs to be able to recall what was done after I get off and look at the unicycle neck (where I assume I would have to attach it)
Any ideas?
I literally only care about cadence but no idea what sort of money you need to spend to get this
Not many basic cyclometers will show you average and max cadence. You’d probably need to spend a reasonable amount of $$$ with something that supports ANT+/BTLE sensors for that.
Plenty of cheapies will show you your average and max speeds though, and since you’re on a fixed gear you can easily convert that to RPM. You can probably even get creative with the wheel size you enter into the settings so that the number is meaningful without conversion.
Take a look at some of the computers from CatEye and Sigma. The models that support average and max speed can usually be had for about $30 or less.
Basically when the wheel is turning they’re recording the trip. You don’t need to start or stop them, they just record when they see motion. At any point while you’re riding or stopped you can view the stats of the current trip or reset them to zero.
That will most likely be your cheapest option, as long as you don’t mind converting the speed values into RPM.
Often the problem with meters is their sample rate is too low. In a sprint they might only take a single reading.
I was working on setting up a digital recording laser optical tachometer that I bought from China for $14. It auto starts and holds fifty samples. It measures the time between reflections so can essentially take every revolution.
I didn’t quite get the mount finished but I found it could pick up a cateye type reflector mounted on the axle when it was mounted on the seat stem.
For as little as $2.69 USD with free delivery you can find a bike computer on ebay. It is a wired one that are reported to be more reliable. I have one on my exercise cycle and had it on my 36er, it is serviceable. The display is a little dim sometimes but I can always read it. It records average speed, max speed and a bunch of other things.
There is a graph and formulas to convert MPH or Km/h to cadence at:
Jim
Thanks
They don’t measure every rotation? I assumed the sample rate RPM/60
Another option would be a Bluetooth cadence sensor like this. Pair it with your phone and use an app like Strava, Wahoo Fitness etc to record. You’ll get pretty graphs.
There are generic sensors like that one on Ebay for ~$15. No idea how well they work though.
Hi Jim I am shaw this has been asked a thousand times , do they all work on 36"ers .
At 14 kph my Sigma 5 stores a speed and cadence reading about every 40 metres. I assume it counting every revolution to get the distance but there is not a perfect correlation between the cadence and speed so I expect the cadence is taking a spot reading by measuring the time it takes to complete one revolution.
On my 36", I had to put a second magnet-pickup on the wheel because the cyclometer I have wouldn’t go above 30". As I had spare parts I saved from various dead cyclometers I had, it was an easy fix. Then I just had to tell the cyclometer that it was monitoring a 18" wheel!
If you only care about cadence, then you can adjust the cyclometer to give you an easier to read result. I did the math once but I forgot the size of wheel you should give it.
Yes the cheapo unit seems to work fine in the 36er with a single magnet. In fact the wheel circumference can be set from 1 to 9999mm. That’s over 10 feet diameter!
It adjusts the speed and max speed with every tire rotation based not how long between magnet pulses. It measures speed from 0.1 to 99.9 mph or km/h
Jim
