Custom "unicycling" jersey-it's easy and not expensive
I just ordered a SoCal Unicycle jersey to wear in the North American Unicycling Competition and Convention (NAUCC) 2026.
It took a few “back and forth” change requests for the “proof”, but that went well. In the end, I had to call them and send a more detailed explanation and graphic for them to get the pedal crank arms right. It should arrive by June 25, therefore, a couple of weeks before NAUCC.
The cost of the jersey is about $45, plus shipping. But, if you purchase more than $50, shipping is free, so I purchased some socks to get the price above $50.
I also got the 5% discount for putting the SGS logo on the jersey, and the 10% discount for using Discount Coupon: REPEAT10.
If you want the same general design, type a comment to “Use the same design as order 2606146939”. You can still change the colors and make changes from there.
This is an easy link to get you directly to the jersey order form. You can also create your own design using their AI generator.
Interested to hear how nice of a jersey it is (material/fit wise) once you’ve got it. Very cool.
It’s due to arrive tomorrow so I’ll let you know.
I got the jersey about a month ago.
I didn’t like the material of the jersey. It would be fine for normal riding, but it doesn’t seem as good as a more professional jersey from other companies.
My “measurements” were on the high side of “medium” so that’s what I ordered. I should have ordered large.
That’s too bad, but thanks for posting it…
I‘d use a jersey made for running, not (b!)cycling. The back side of your sample is tailored to cover the rider‘s back when in a bent position on the b!ke. Unless you use an aero bar setup on your uni you gain nothing, instead you risk the jersey to catch the seat and getting in the way when you want to dismount. I took this issue into consideration when I bought a new rain jacket - not every model was unicycle friendly.
