Custom Kris Holm Unicycles
no k1 cranks as there only compatable with k1 hubs,the light stuff cant even be used for trials.
ive got a cf base,tensiles,seat post and pedals coming,my KH will be down to 4.6kg
I have my K1 light cranks on my KH hub what are you talking about? Are light cranks lighter than tensils or ventures or not?
do your crank arms come loose often?
Koxx ‘Lightweight’ ISIS Cranks
Lightweight solid cranks to fit Koxx Isis hub, available in 110mm, 125mm 140mm and 160mm lengths.
Made of 7075 aluminium anodised black with steel inserts for pedal threads. Fits 10 splined Koxx Isis hub. Has zero q factor.
Weigh only; 511g (110mm), 550g (125mm), 580g (140mm) and 633g (160mm) per pair.
Sold in pairs. Must be used with washer that fits between pedal and crank to avoid damage to crank.
We only recommend using these cranks with the Koxx Isis hub.
Onza ‘Tensile’ ISIS Cranks - 140mm
As fitted to the Onza ISIS Trials unicycles, these have been developed from Onza’s bicycle cranks but designed to be more robust to cope with the extra stresses unicycling inflicts on cranks.
Onza have used tried and tested trials bike technology to produce lightweight unicycle ISIS cranks
Features:
ISIS spline is strong and creak-free Incredibly stiff and concentrates metal in high stress areas.
High tensile strength 7075 T6 Aluminium, polished
Medium Q-factor (outwards flare) maintains adequate ankle bone clearance
Broad, flat profile is optimised for trials and street riding
CroMo pedal inserts
Length: 140mm
Weight (pair): 410g
These will fit all ISIS hubs except Koxx ISIS hubs.
these were copied from UDC-UK.
the nimbus cranks arnt 140mm.
why would all website lie about compatbility?
The old hubs were not true isis. The new ones should be but not a lot of people have confirmed it.
And even before the switch you could get it to work if you add spacers and tighten it a lot or something.
My kh20 and my new kh29 with magura brakes from brycer. He is very helpful and has great prices!
I mean they do kind of scratch the bottom of the frame sometimes but other than that they’re great!
Okay :slight_smile: guys. but does unisalg.com (UDC Denmark) have shiping to Canada?
Moments are useless for trials.You can really feel 200grams difference when youre riding it
except if you drill them right?
correct
Nice unicycle :slight_smile:
Now, this is my unicycle. I finally got my White KH clamp and my White Qu-ax pedals.
looks nice but a less blury pic would be better :smiley:
Specs :
-Carbon fiber seatbase
-KH seatpost
-painted flu-yellow KH seatpost clamp
-Painted purple (needs a recoat) KH short neck frame
-KH wheel with white tryall tyre
-rollos
-Odyssee twisted pc chameleons yellow pedals
How are there rollos on a uni from March 19, 2008? :astonished:
Edit: Okay! I should have figured out the date was wrong…
oh the date isn’t right …
hahaha I just realized that. I took the pictures today :roll_eyes:
Will a Kris Holm frame fit on a Koxx One wheelset? I looked it up and found this thread but didnt help too much. :roll_eyes:
Thanks,
Nice uni Max, I shipped you tire on thursday and you already got it! The guy told me it would take 3 days:p Next time I think you should put a few more coats of paint… like 20:p
Yes the KH frame fits K-1 wheel… I can’t find a picture but I did post one on the forums one day…:slight_smile:
Yeah it will, that’s what I have.
haha yeah it came fast!
thanks a lot :slight_smile:
And yeah, I had put a lot coats of paint, but I dont think i put on enough clear coat to protect it.
