Well okay but that sorta throws out the whole measuring part. And I think that part is important.
The ISIS standard is:
âThe standard instruction for determining the required spacer thickness is to push the crank on by hand and then select a spacer about 3 to 5mm less then the space from the bearing to the crank. With the correct spacer the crank will fit tight on the tapered ISIS spline and against the bearing when the attaching crank bolt is tightened.â
Some call for 2mm space but that seem low with the official ISIS spec calling for 3 to 5mm. So you should be ok with a thinner washer to provide a 3 or even 4mm preload.
UDC UK told me 6mm or 7mm for those cranks. I use 7mm on both sides. Why different spacers on left/right side?
Just because the calipers measured different gaps on each side.
Thanks for that link. Havenât read this information yet (didnât know it existed).
Hey RB,
After you âtightenâ the crank bolt, try this.
Tap the end of the crank or pedal a few times.
Is there any looseness?
If there is, then it means two things:
a.) That means the conical outside geometry of the spline + conical inside geometry of the crank is loose. Solution: buy some brass shims(.001-.010" thk are available from mcmaster-carr, or jam some aluminum foil) between the spline and crank. This will close the gap.
b.) The compression length wise of the screw against the crank + shim is loose. The screw bottoms out and canât bring the two parts any closer. You are just âcrushingâ the bottoming out of the screw.
Solution=add a washer that will fit. Then screw has more threads to move and âcrushâ properly.
Good luck
There isnât any looseness after I tighten. The whole thing is super tight.
FYI for those that have helped - this is what I did today. And hopefully for anyone reading in the future that is searching for all-things-loose-cranks:
- I took the cranks off and redid the whole thing
- I used the 3-5 mm rule instead of 2 mm (honestly I think this is gonna fix it)
- The above point led to smaller spacers (9 mm and 6.8 mm spacers)
- I extended the arm of my allen wrench and was able to get the bolt tighter
Iâll probably follow up, but if I donât - itâs because its working well.
Thanks again everyone.
In my experience, you donât have to gorilla the crank bolt. Tight is right, but overtight is not. But indeed it is important to recheck the tightness of the bolts a few times after mounting cranks (and riding them some). More frequently in the beginning, but even after a year they might work loose somewhat. This is normal and no cause for concern
Good to know. Thank you.
And cottered cranks as well, in case you encounter any antiques.
Speaking as an old guy who as way more experience with square taper (and cottered), cranks are one of the parts on the uni that have the most torque applied to them. Itâs not unusual for them to have some looseness during the first ride after re-install. In the past, when I rode mostly square taper (Coker), my personal rule was to give a little âpushâ with a wrench on the cranks and on the pedals. Keeps you from having to walk as much. Though in recent years, I havenât done much of that due to splined 36" and splined Muni. The pedals stay tight because I basically never idle or go backwards on those.
Heyyy I know of you! Thanks so much for the comment.
One side note: not all ISIS bolts are the exact same length (extreme example: the KH rolodisc bolts).
So it would be good to check/verify the length of the bolt whenever there is a suspicion of bottoming out
Use the same on both sides. Thereâs no point having different sizes on the two sides. You might need to do one side up rather tighter in the first instance, but all will be just fine. The tighter crank will just deform slightly more this time.
Then which side do I measure? Doesnât really make too much sense to me. What is the detriment to using two different sized spacers? What does it hurt?
I would use whatever size is required on each side, no matter if they happen to be different or not. Spacers are cheap and it makes sense to use the correct size.
And the interface on aluminium cranks is malleable, and will be perfectly happy being smushed on slightly more.
Using different length spacers just forever means youâve got to remember which side is which, or keep measuring, and youâve got to buy two sets of spacers as the come in pairs of equal lengths.
One crank will of course be slightly closer to the centre of the wheel than the other too, but I suspect very few people (if any) would be able to tell that.
Whatever you do itâll likely be better than most unicycles seem to be from the factory, manufacturing tolerances seem to mean that spacers are rarely the perfect length on new unicycles.
Right I agree.
I donât have to remember anything, though. I have a set of calipers and just take the 10 seconds every time I change cranks to measure the gap. I dunno; it doesnât sound like a big deal to me BUT I donât change cranks everyday. If I had to change cranks constantly Iâd probably cut corners.
I appreciate the notes and discussion. Iâm still learning
