I have a Koxx one hub on its way from renegade and I am going to be needing some spokes to go with it when I build the wheel. Unfortunatly I cannot find the statistics on the Koxx one hub. I need to know what the spoke hole diameter, hub width, and hub diameter are. I have been told that the hub diameter is 60 mm so I guess I don’t need that.
Also I was wondering if there is any point, how hard it would be, and whether or not four cross would affect the performance of the wheel.
I ask this because I was thinking of getting some white primo forged spokes and the shortest length they seem to have are 182 mm long. If this is just too much work than it’s worth than I guess I won’t bother.
Just call Renegade and ask them for the hub dimensions and what spoke lengths you will need to use. (You willl ned to tell them what size rim you plan to use though)
Because taking it to a LBS is needlessly expensive, I can build a wheel and I can true a wheel with both 2 and three cross, that part isn’t hard at all if you have the right tools (and even if you don’t its not crazy hard).
Unfortunatly I know little about it other than how to do it.
