Re: Competition cycling…
Jason Richards (jazz@cs.uq.oz.au) wrote:
: After much deliberation on the matter, I am thinking of building a 20" wheel
: with internal gears (seven speed) in the hub - I found a German manufacturer
: (* Sachs??? *) which makes excellent quality internal gears for racing bikes.
: A little over the top? Maybe…
: Anyway, I would like to finish building this uni sometime in the next couple
: of weeks and ride it in the triathlon! 40 km (25 miles). Has anyone tried
: this before?
I haven’t tried it but I’ve thought about it quite a bit. I think the biggest
problem you face is figuring out how to lock out freewheeling. This “feature” is
inherent in all types of bicycle transmissions. (One exception is a special
Sturmey-Archer 3-speed, made for track racing bikes quite a few years ago. If
you find one, I’ll buy it from you!)
Having taken apart a Sturmey-Archer 3-speed to learn how it works, I concluded
(though I could be wrong) that it would be far from trivial to prevent
freewheeling. If someone can figure out a way, a world of unicyclists would
wobble a path to your door.
I’ve seen a picture of a uni with a derailleur and some kind of mechanism to
lock out freewheeling. It’s in On One Wheel from sometime in the 80’s. I’ll try
to locate it.
One solution might be to use a motorcycle gearbox, say from a Honda trail
scooter, but never having seen one, I have no idea how big or heavy or
adaptable that would be. But at least it bypasses the freewheeling problem from
the git-go.
Another solution, invented by Tom Miller, is to use an axle within the axle. The
inner axle (I think) carries a sprocket, call it the right side. The sprocket
drives a chain which drives a third axle that passes through the frame above the
wheel. The left end of the upper axle carries a sprocket that drives a secondary
chain. The secondary (driven) chain connects to a sprocket on the left end of
the outer axle on the wheel. There is only one gear available at any time, but
it can be any ratio.
Another solution I’ve thought of but not tried, is to use two sprockets and a
belt or chain, in a setup like that used to control the speed of the chuck in a
drill press, or two bicycle freewheels. To wit:
___________ ______
|__________| __|_____|_ ______|===============|_________|__ ___|
|belt/chain |______________|
Driving sprockets Driven sprockets.
You would still have to stop to change gears (at least I would!), but they would
be available a lot more easily than changing wheels or unis. There is no gear
changing mechanism involved, you just move one end of the belt/chain from a
larger sprocket to a smaller one, then move the other end to the corresponding
sprocket at the other end. The gear sizes are stepped such that the length of
the belt/chain is the same for all combinations. I should say that this is
probably practical only on a uni that already is built for chain drive, i.e. a
giraffe. You might need a simple tensioner to keep the belt/chain tight.
Something to think about, anyway. Good luck and keep us posted.
| Mark Schecter | “Please identify yourself.” |
| schecter@tfs.com | (Self checks pocket mirror) |
| | “Yes, that’s me.” |
