A new vs an older QU AX 24" Muni with disc brakes. How do they compare to each other and even other brands. this is part of an email I received. I see that the older one is 48 spokes, new 36 spokes with Q Axle. I do not really understand the differences. I was interested in the older one due to the lower price. Any huge differences or red flags etc.? Anything vastly superior or inferior?
This is the newer model QU7527
light disc-braked unicycle with the Q-Axle-system, durable, light, rigid – an excellent choice for technical downhill.
· Q-Axle-Disc hub, 36 holes 24 mm holow-axle, red
· light QU-AX Q-Axle dualhole-cranks 125 / 145 mm, ti-grey anodized
· QX Eleven saddle, designed by Kris Holm
· QX-series aluminum double-clamp
· QU-AX double-walled rim, aluminum, 36-holes
· Duro Wildlife Muni-tire, 75-507 (24″x3,0″)
· QX-series [lucent] pedals
· aluminum Flatcrown frame, anodized in black
· aluminum seatpost with reinforcement gusset, Ø 25,4 mm
· Shimano-discbrake, 160 mm QX-series rotor
This is the older one QU7515
QX-series Disc-hub, alloy-axle, hollow-drilled, M15 screws
QX-series 160 mm rotor
QU-AX 6061er alloy cranks “one”, 145 mm
QX-series [luna] pedals
QX-series disc-frame with postmount-socket and gauge-guide
QX-series [twice] seatpost clamp
QU-AX alloy seatpost, black, gusset
QU-AX muni-saddle with white bumpers
24"x3.0" Duro Wildlife-tyre
QU-AX DB 24X-Disc-rim, black, 48 holes
Brake-lever-mount for saddle
Shimano BL-M-445 brake
