I plan to unicycle to school this coming year and I’m searching for a good backpack for unicycling. the things i’m looking for are:
sleeve for laptop
water bottle and phone pockets
somewhere to put my helmet
Any recommendations?
sleeve for laptop
Can you provide the link to that bottle cage? I’ve been needing one that can fit one of my unicycles for ages.
@Oridemic, I’ve been playing around with bottle mounts. The biggest issue is that UPD’s put so much more strain on bottle cage mounts.
Here are three I tried.
I recommend the Patagonia blackhole backpack
The daisy chain works well for helmets using a plastic niteize S-Biner or hook and loop strap
The Patagonia Blackhole looks like a quality pack. And, it looks like it might be water proof or water resistant.
If you would like one a little smaller, and one that is the best fitting pack I have ever worn, then check out the Topo Designs Klettersack. When you wear it, it doesn’t shift and it doesn’t move.
https://topodesigns.com/products/klettersack
You will have to strap/hook a helmet to the outside, though.
