After riding the Coker for nearly 200 miles (120 miles on a KH saddle,
and almost another 80 miles on a Torker air-saddle), I’m finally ready
to begin fiddlin’ with the tilt of the saddle. Even with the added
cush provided by padded cyclin’ shorts and an lovely air-saddle, I
still can’t quite break that elusive 30-minute barrier. Time to tilt
the saddle. To that end, I just bought the 22.2mm Primo rod, and am
now eager to also purchase the Kinport-type rail adapter. Sadly, the
Kinport-type adapter is no longer in stock at Unicycle.com. Can you
give me any hints about where I might find a fairly low cost rail
adapter? The KH adapters look nice, but my sense is that they are a
wee bit more money than I’d like to spend. Thanks for any help you
can provide! --carl (North Dakota)
Jeez, I just ordered a Kinport rail adapter, hopefully I got the last one and they werent out of stock.
Keep in mind that the Kinport rail adapters are designed to fit the bolt pattern on the KH seat. If you want to use your Torker air saddle you’ll need to get the more expensive KH branded rail adapter that is designed for the Miyata seat (same bolt pattern as the Torker).
Carl, if you have an extra old seat post, you could always do this:
http://www.unicyclist.com/forums/showthread.php?s=&threadid=35030
I have a miyata that I will be using the Kinport rails adapter on. Maybe he did the same thing as me and bought a CF base.
Re: Coker-types: Need advice on rail adapter…
“Krashin’Kenny” <KrashinKenny@NoEmail.Message.Poster.at.Unicyclist.com> wrote in message news:<KrashinKenny.1e81ld@NoEmail.Message.Poster.at.Unicyclist.com>…
> http://tinyurl.com/6tgn8
Kenny-- Brilliant! In fact, I have an extra 22.2 mm seat post, and so
I’ll try to imitate your solution. Thanks for sharing the fruits of
your creativity. --carl (North Dakota)
ObieOne and John-- I guess that I should clarify my earlier missive.
I have two saddles for the Coker, a KH and a Torker Air Saddle. My
first inclination was to purchase a rail adapter for Torker Air
Saddle, but after browsing the selection at unicycle.com, I decided
abandon that notion and buy the less expensive Kinport model. My
thinking was that if my saddle-tilting efforts failed to significantly
improve my ‘seat-time’, then I would only have misinvested about 30
bucks on a rail adaptor. The upshot, then, was that I hoped to use
the Kinport rail adapter to mount my KH saddle (and not the Torker Air
Saddle).
I’ve two unicycles that I enjoy riding: the Coker, and a Yuni 29er.
If the saddle-tilt adjustment works to my satisfaction, then I’ll
undoubtably purchase a second adapter for the other saddle, the Torker
Air Saddle. Since seat post diameters are the same for both unicycles
(22.2mm), I can mix and match saddle and unicycles. (Candidly, the
jury is still out on the Torker Air Saddle. Each saddle has it’s
attributes, but I seem to get about 22-26 minutes of pleasurable
riding time with the KH, and only 18-22 minutes with the Torker Air
Saddle. Saddle-tippin’ experiments may prolong these times, i hope.)
Regarding Bedford Inventory: I browsed the online catalog earlier
today, aturday, but failed to find the Kinport rail adapter. I’ll
give the catalog another peek. I obviously overlooked it.
Thanks for your help! Toodles! --carl (North Dakota)
“TheObieOne3226” <TheObieOne3226@NoEmail.Message.Poster.at.Unicyclist.com> wrote in message news:<TheObieOne3226.1e82ze@NoEmail.Message.Poster.at.Unicyclist.com>…
> john_childs wrote:
> > *Keep in mind that the Kinport rail adapters are designed to fit the
> > Torker). *
> TheObieOne3226 - Judge me by my size, do you?
> [image: http://img54.exs.cx/img54/4743/yodaweedresize.jpg]
> http://gallery.unicyclist.com/SWAT
> singlewheeledattackteam.1hwy.com
> TheObieOne3226’s Profile: http://www.unicyclist.com/profile/4851
> View this thread: http://www.unicyclist.com/thread/35652
Re: Re: Coker-types: Need advice on rail adapter…
The catalog on Darren’s web site is way out of date and wasn’t even complete at the time. To find out what Darren’s got, and how much it is, you have to call him or email him. He’s got a good selection and even has stuff with a unique Bedford flair (like special colored painted frames and hubs and rims).
The GB4 seatpost is good and strong. It has about a 5 degree additional tilt compared to a standard seatpost. Unfortunately, my Coker seat and muni seats are tilted at more than 5 degrees. I do use the GB4 seatpost on my freestyle uni with a Miyata saddle and does improve the comfort.
Saddle tweaking just takes a lot of experimentation. You have to be willing to try things. Some ideas will work and others won’t. The ideal angle for you will also take some experimenting. Changing the angle by just a degree can make a difference.
Your riding posture also plays a role in saddle sit time. If you slouch forward or roll your hips forward you’ll get numb or sore faster than if you sit up straight and sit more on the back part of your butt (at least that is the way it works for me). Learning how to pedal more smoothly also helps so you don’t bounce on the seat as much. Pushing down on the nose of the saddle or handle on the saddle will help you get some weight off the saddle and extend the saddle comfort time. Good padded cycling shorts along with chamois cream like Chamois BUTT’r also help a lot with saddle comfort. Trying a different brand of shorts may help if your current shorts aren’t doing the trick.
Last time I heard from Darren, he had Kinport adapters with the Miyata bolt pattern in stock. If thats what your after, definitely shoot him an email. He generally responds very quickly.
Ben
I got a reply from Darren about rail adapters yesterday.
“KH / 27.00 US - KH with brake post / 35.00 US - Miyata / 27.00 US”
An update: Darren responded promptly to my inquiry about the Kinport
rail adapter. He said he had one in stock (for $33 US, which included
postage for air delivery). The Miyata/Torker rail adapter is
out-o-stock right now.
Trying out the GB4 seatpost seemed like a doable idea since I just
happened to have a 22.2mm version in my spare parts bin. I cut the
post to fit the 29er, mounted a KH saddle, and went out for a 45
minute ride. The route taken, a 4-mile loop through the UND campus
and adjacent residential neighborhoods, did not permit me to try to
braek the 30-minute ‘seat-time’ barrier. Traffic, a gusty 10-15 mph
NE wind, and frigid temps (in the high 20s) made conditions less than
optimum for sustained riding. I can say that I did like the feel of
the tilted saddle–a noticable difference in comfort for the KH
saddle. (I also noticed that the more ‘nose-up’ position had a slight
affect on my freemounting…strange how a subtle, almost neglible
change in the geometry can put the CNS into a new learning situation.)
I’m going to invest a few more hours of riding time with the
KH/GB4/29er combination before deciding to go the rail adapter route.
We’re entering the season of lousy weather for Cokerin’ here on the
northern fringe of the prairie. I’m aimin’ to ride the 29er as much
as I can before haulin’ out the cross-county skis. Thanks for your
PS: I’m going to start another thread about studded tires.
