HI
I own a Coker and I want to know the standard crank size and what is the best
crank size for faster speeds. Are smaller cranks faster? If so where can I get
really small ones?
HI
really small ones?
Re: Coker cranks! need help
Kip,
> really small ones?
The standard cranks (unless you got them from the first batch) are 6".
Shortening the cranks does not let you ride faster. They make you ride smoother
with less stress on the knees. Your average speed increases when you put shorter
cranks on because you ride more consistently - but is harder and more dangerous
to ride as there is less chance of recovery.
Roger
The UK's Unicycle Source <a href="http://www.unicycle.uk.com/">http://www.unicycle.uk.com/</a>
Kip Koski wrote:
> HI
> really small ones?
___________ =========================================== ___ /_/ / / / /
Kevin Gilbertson - <a href="mailto:mail@gilby.com">mailto:mail@gilby.com</a> / _ '/ / / _'\_ / Unicycling
T-shirts at <a href="http://www.gilby.com/">http://www.gilby.com/</a> \_ /_/_/,___/ / AIM/AOL:
UnicyclingGilby /\/ /__________/ Unicycled Across Minnesota to help
others! \__/ ================================================
