Nice ride, and great view!
How did you attached the poll to the frame? And what the purpose of the wire that youāre holding?
Ahhh yes, and What about a special phone cradle?
Thanks for sharing,
UVcycle
Iām also curious about this.
Thanks alot! And the whole attachment between the poll and the frame is really hard to explain, because it was kind of hard to makeā¦ I used some wood planks, and and made āa second cycle forkā, and I connected it with the real fork. The GoPro was placed on a plastic tube that was connected to the home-made āforkāā¦ It was not a brilliant solution, but it worked. You would just have to be creative if you want to make something like thatā¦ When I started cycling, the whole camera pole went up and down as i tried to balance, and it shaked alot. To keep it from shaking that much, I secured the pole with some kind of rubber ropeā¦ It worked okay, and it didnāt shake that muchā¦ Until the rubber rope started to fall apart while I was filming the rideā¦ Then I had to hold the rope by hand all the way to the top - I wouldnāt stop and fix it, cause of the on-going filmingā¦ At the top i fixed it thoughā¦ And that phone scene was just my Samsung phone falling out of my pocket, hitting the ground and falling apartā¦ I hope you did get SOME answers, and thanks for replying!
