that sucks…i have the kh style…
If Scott is reshaping his bases to fit KH hardware then there is no doubt that he will redo his death grips to fit his new bases well. I wouldn’t worry about it.
Oh yea, you already said that huh Brian…
Thanks again…
hehe
Im getting exited…![]()
Hye brian?
do i need to spray tac the foam back on the base when i get it???
How did you break it?
seat whip? because that is how i broke mine.
whats seat whip?
“wow.
that looks exactly the same…
okay well if you have seen m,y videos you have seen the 5 stair outside my house…
its pretty long…lot that high…
but yea…
so its not a lot of run up to get speed…
so i booked it. and made it all the way but landed with only one foot on the uni…
so i was kinda stadning and coudent keep my wweight and fell right onto the front of the saddle…snapping it…
i thin kit may have inly been cracked but anyway i didnt really realize that it ws broken… ao i kept riding…
i tried to crankflip and i knew it then…”
You should get a plastic base. I mean you have bad form, your broke a god damn dx rim. I say break more plastics before you break anything else expensive.
well. i cant order a new plastic base.
i already ordered a cf base.
and have you even snapped a plastic base???
Don’t you do street? I don’t think you really need a death grip, I heard they break hitting the ground. What is wrong with kh handles?
One, from bad form. My other one was flexy, but was ok. I have 2 cf bases now.
read through all my posts through.
then post.
I’m lazy, sorry. Your one to talk about posts =p.
hey.
im getting better about them.![]()
and i said im not going to get a dg probly.
Yeah, fileing isn’t that hard. I did it, just take your time. Oh yeah when you installing the handles / tightening if they free spin don’t worry, there is an easy way to fix that. Get 2 sets of bolts, regular and lock alright. Put the regulaer ones on first, you should be able to use your fingers then install the bolts with nylon or whatever. Ohterwise the they will start to freestpin since the losck nuts go on rough. Do it for every bolt and make your life easy man.
Get what I mean?
He really has gotten better. Since I started mentioning it I haven’t seen any of the annoying useless posts from him. He’s learned. ![]()
Now we just have vanpaun to worry about.
unidude, I’m not sure what you meant when you asked if you needed to spray tac the foam on. You can just put it on and put the cover over it like normal, you don’t need to glue it or anything.
Haha, yeah. I had my share of horrible posts, I can’t really complain… well I had more than my share, but lets keep that under wraps, shhhhhh.
Umm then will i need to do the rubber hose thing that it says in the manual???
seat whip. i saw this video and wanted to try one. almost got it but i landed on my seat and not the tire
hey thanks bro.
Man that must have been a bad crash!!
