Beard DX Power Ball
Beard DX Power Ball
A range of ultra-heavyweight balls, evolved from the DX ball as an aid to improving endurance and muscle tone, and also used in physiotherapy and aerobics. Made in the same 3 sizes as the DX, but filled with tiny steel balls, Pow³r Balls are a practical alternative to working out with giant balls. A proper warm-up is recommended - this is serious exercise!
Metallic Green, Metallic Purple, Metallic Black
Small 62mm, 450 grams
Medium 68mm, 600 grams
Large 75mm, 800 grams
What are these like? Do you get massive muslces (becasue i don’t want any!)
Re: Beard DX Power Ball
What are your intentions? Some numbers jugglers i.e. those doing high numbers like 7 and up, use these type of balls for building up muscles and endurance.
Rule of thumb in weightlifting is that low weights with many repititions will tone your muscles, while high weights for fewer repititions will bulk them up.
Unless you plan to juggle those things for hours at a time, you’re not likely to develop massive muscles.
The only use I have ever personally witnessed those type of balls being put to was to toss them to an unsuspecting person who thought they were normal weight balls.
Good luck,
Raphael Lasar
Matawan, NJ
