juist kinda fling em up wards milliseconds b4 ur on the uni, when ur in mid air, then they are in front of you
if youre having these problems just riding, do NOT attempt a suicide mount yet!
whats a suicide mount?
get air seat
it’s a cool looking mount that I can’t do correctly yet
a good way to learn to land on your pedals. if you don’t it is generally painful. you hold you uni in front of you and then jump on it with out holding on to it.
Should i get a lighter uniccle so i can do unispins? I was gonna buy a DX but Jerrick mentioned it was pretty heavy. Can u still do freestyle type moves on it?
as i said before:
you dont modify the seat, or your riding style or what you wear.
you modify yourself.
weve all done it. There is a special sergeon that does unicyclist’s half price due to a deal Gilbly struck up about a year ago but now has forgotten about so dont even bother asking him
shirt trick
lean forward a little. tuck your shirt in so that it is just behind the ‘boys’. when you stand up your shirt pulls them safely out of the way.
Clever!
The one you have will work just fine for unispins and other freestyle tricks where you don’t need to put your feet on the frame (like wheelwalking). The DX will work for freestyle tricks, just not as well as a freestyle unicycle will.
After a long day of riding, my groin is all sore. Then the whole next day i cant ride cause im too sore, is this normal? Also, one time i went off a curb and my hand holding the seat smashed my balls and it hurt very badly. I just kind of knelt on the ground clutching my balls for like 5 min. Any tips?
lower the seat, grorin soreness is normal if you can try tilting your seat back so your weight is on your butt not your balls and when going off things just hold your seat stand up a little and whenyou land roll out and try to hit the seat softly… if anyone has anything to ad please do… this is just what i have seen since I joined the forum.
Sounds like you’ve got chafing problems. Chafing is when your shorts / pants / underwear / saddle / whatever rub and irritate your skin. Your skin doesn’t like that and gets sore. In extreme cases it can get infected or cause saddle sores.
You need to reduce the rubbing that causes the chafing. Avoid shorts that have seems in the crotch area. The seems will cause chafing.
The spandex style cycling shorts are the best way to minimize or eliminate chafing. The cycling shorts are tight fitting so they don’t rub. Spandex style fabric is also slippery so it slides against your saddle instead of chafing your skin. There are also creams like Chamois BUTT’r that you rub liberally on the pad that is sewn in the cycling shorts. The cream further reduces rubbing and keeps the skin from getting irritated.
Spandex style cycling shorts also have an additional benefit in that they keep your dangly bits snug and in place so you don’t sit on your balls. The cycling shorts need to be snug enough that they properly hold things in place. You also wear cycling shorts sans underwear. The shorts are worn next to the skin.
There are also special jock straps called suspensories that a few people use. You’ll want a style that doesn’t have the straps going under the crotch. You don’t want something with seems where you sit on a unicycle seat.
Actually, my seat is too low, im looking to buy a bigger post. Sometimes my knees are a little achy too. I think i need a taller seat so my knees aren’t so scruched up.
good Idea
if u want to protect family jewels
to stop pain try standing up and riding or ride sif i u can
although riding sif can give u sum pretty nasty brusies on ur thighs
what seat do you have?
Theone that comes with the torker CX
I used to have one of those rocks a while ago. I’d say you might want a better seat, but not many other seats mount to that seatpost type.
i just push them forward with the seat when i mount
