Avenir 20" Mountain Unicycle
Is this a decent unicycle? I want to start cycling…
http://www.amazon.com/Avenir-Mountain-Unicycle-20-Inch-Wheel/dp/B00165Q9FS/ref=sr_1_5?ie=UTF8&s=sporting-goods&qid=1263960556&sr=8-5
Most people get a 24" diameter wheel with a 3" tire, or 26" diameter wheel for technical Muni. You can also get a 29" wheel for less technical trails and longer distances.
That 20" unicycle will be very slow on the trails and it won’t have as much momentum as a larger wheel needed to overcome obstacles such as roots and rocks, and won’t absorb shocks as well as a uni with a larger volume tire.
You can do Muni on a 20" but as a beginner you will be falling a lot and it probably won’t be much fun, at least not for long distances.
Go to unicycle.com and look at their 24" or 26" off-road Unis; they have a much better selection than amazon.
Edit:
IIf you’re just getting into unicycling and not necessarily looking for a Muni, so you can ignore these comments, sorry. But still I’d recommend looking at unicycle.com
i apologize for such a late reply. It looks a lot like the nimbus 19" trials uni just with lesser cranks. If its strictly for muni-ing id go with a 24" at least. if you want to get it for some muni and some trials/stree and your a beginner it be perfect.
check this thread
