You’re right - height is most probably a key factor for a 360. Perhaps
holding the arms in close to the body would help the spinning part to. Dan
certainly gets some good air in the video when pulling a 360 but I can’t
remember about the arms…
Neil
-----Original Message----- From: opaugam@aptilon.com
[mailto:opaugam@aptilon.com] Sent: 19 June 2001 16:22 To:
n.dunlop@kildrummy.co.uk
Cc: unicycling@winternet.com Subject: RE: aerial 180 or 360 [was
jumping higher]
I can almost do the 360 statically - I found hopping heigh was the key for
me, I was way too low and not quick enough to spin.
I found also that a 180 (and tentatively a 360) is way easier and fluid
without grabbing the seat by hand but rather by compressing it with the
legs. This one was not tried while riding but would look real cool.
Oli-
-----Original Message----- From: Neil Dunlop
[mailto:n.dunlop@kildrummy.co.uk] Sent: Tuesday, June 19, 2001 11:10 AM
To: Olivier Paugam; unicycling@winternet.com Subject: RE: aerial 180 or
360 [was jumping higher]
For me (I think) it’s like coming to a mini and ever so brief standstill
then launching yourself round bringing the uni with you. Preloading your
body by swivelling at the waist slightly to the opposite direction to
which you are going to spin also helps me get round. This preloading is a
last minute thing and forms a fairly fluid motion - grab the handle…
the rear pedal is at the lowest position before it comes up to
horizontal… rotate shoulders to the left… rear foot stops rear pedal
as it hits horizontal… brief stationary moment… launch up on the
pedals… twist shoulders round to the right bringing hips and,
hopefully, the uni with them.
I can’t (yet) get any further than 180 and can only ride off forwards
after landing. How Dan pulls 360s in Universe is beyond my comprehension.
I can’t even do that in the spot let alone moving. Oh well… practise,
practise, practise is how the mantra goes.
Neil
[mailto:opaugam@aptilon.com] Sent: 19 June 2001 15:36 To:
unicycling@winternet.com Subject: aerial 180 or 360 [was jumping higher]
Importance: Low
Since we are into the jump/hop topic, I have big troubles initiating an
aerial 180 or 360. I can do it in the static form, ie hop + twist but the
ride + jump + twist is not working good (the max I get is a 90).
Any tips on how to initiate this move ? It seems I can’t twist enough my
upper body and/or my legs are too busy switching from ride to jump.
Oli-
opaugamATaptilonDOTcom !
