Advance Idling 2025
There was a funny moment. Recently I felt I reached a plateau with my idiing (no progress, 100max idles with the left foot low and 20max with the other one) with a tend to lowering. The real reason turned out to be that the tire pressure had dropped to 20psi. After I pumped the tire up to 40psi the things went better.
The weather became better and I relocated outdoor and changed to a 24" uni with 145mm cranks to continue with idling. Hope to make some video soon.
Hi Slamdance
I am interested in backwards riding.
:grinning_face:
Now I’m trying to perfect this pattern gradually increasing the number of swings with each leg down.
In addition, you can change your leg by doing half a rev back instead of forward
Me too.
Nice day for unicycling, Aye Huku
Thanks for your video, again.
Yes, please check your tire pressure.
High pressure = stiffer tire = more response!!!
I also notice something about your seat position.
I know it’s preferable to go high seat = less muscle work = more leverage for riding distance.
When the seat is high:
a.) The leg is straight at 6 o’clock(bottom pedal) and leg muscle is relaxed/resting.
b.) The leg when pedal is at 12 o’clock does not bend so much.
High seat is for long distance riding efficiency.
Let’s do the "opposite:
a.) When leg is at bottom pedal, let’s keep it bent. So, muscle is active and not resting.
b.) When leg is at top pedal, let’s bend knee as much as possible. So, muscle is at strongest flexed position.
You will gain more “feel” and “sensitivity” when more muscle is used.
You might feel a little sloppy and unstable in the beginning, because the smallest movement will be amplified on the unicycle. However, you should be able to master it quickly. I believe it will help you develop more feel and control. The price is more energy, muscle and fatigue.
I won’t go into the science or mechanics behind “low seat/more muscle” reasoning, because it’s somewhat complicated. I just deleted 3 paragraphs trying to explain. I want you to just try and let me know how it goes. Okay.
…slam
Hi, Slam,
As usual, Thank you for detailed analysis.
Yes, my bigger uni is out of use now for some reasons and I used this 24" one for commuting just before these exercises and the saddle remained at the riding position. My fault… Will try to change the height, see what is resulting and report.
And, perhaps, it would be worthwhile to pause the exercises with 20" now, so as not to mess one with the other, right?
What a pity! It would be very interesting to read these 3 paragraps… I am a mechanical engineer by education and unicycling is interesting for me not only as a sports but also as a mechanical process.
Thank you again for your work.
I set the saddle 3cm lower. If in short, the system became a bit less stable, but more controllable. The last achieved (I think so) due to 2 factors:
  • smaller moment of inertia related to the contact spot => faster responce;
  • more freedom in leg’s movements => control action is stronger and faster.
I tested that with my 20" uni, because all the necessary is on hand.
24" test will follow outdoor.
Thanks for advice.
UPD:
About 24" test with lowered (ca. 5cm) saddle.
I managed to do ca. 20 idles (fwd+back) with my hands crossed on my chest.
Another result of the saddle lowering.
I had 2 juggling balls with me and tried to do a swap while riding. It worked pretty well as never before. I wished I had a third ball. :man_juggling:
All that thanks to the low saddle.
PS: My wife with a camera was not nearby, so no video this time.
Hi Huku,
Glad to hear your progress.
Actually, I am also an ME. Maybe I will get into the physics of unicycle maneuvers next time.
I don’t like to use equations or free body diagram explanations, but rather reference what we feel and body motions that generate forces. Explaining unicycle movement is complex, because it is dynamic and coordinated(timing). From our heightened sensitivity on the unicycle we must apply instant, precise and measured reactionary motion to balance and stay on or fall down.
I was out riding and trying to “practice” what I preached regarding “lowering the seat” for better control. So, I lowered from 150cm to 135cm, which felt a little strange.
However, I noticed some small observations:
1.) I felt more control during idling, because my knee and legs “had to” generate more force. Not a lot, but more than normal. I noticed I used “less ankle action on my pedal” and more “flat pedal with straight push down” for balancing.
2.) During SIF training I forgot about this, but in order to SIF ride you must “squat down” a little bit in order to do it. It’s almost as if, I had dropped my seating post 150 to 120cm. Thus, making my legs bend and work harder. However, this equates to more control and balance. (I am a beginner/intermediate level at SIF, I know advancers can stand straight up).
So, I hope this encourages beginners to “drop that seat” for better idling performance. Then later, as you get more advanced you can raise the seat up again.
Keep on…slam
:red_question_mark:
Did you mean mm (marked on the seatpost)? Or are you riding a giraffe? Or…
:open_mouth: 15 cm!
I have never measured my seat height before. I think it should be measured from the lower pedal to the lower point of the saddle, so we can compare it to the inseam leg length. Measured this way my riding height of the saddle is 87 cm, while my inseam leg length is 85 cm (isn’t my saddle too high?? Perhaps it is a bad habit, which results in too strong ankle action. Are there any rules in this respect at least to start with?).
I tried to lower my seat 5 cm more (10 cm in whole compared to usual riding position).
The results:
  1. My “idling” turned to “working” by both of the legs with a full control of the unicycle at any moment. Now that process is not that stable as i wish, there is still some work to be done, but the result encourages. I even can stillstand at some points (esp. rear one) an then continue “working”.
  2. I learned that there is only a half a step to SIF for me. I stood up on my feet while riding with that extra low saddle, pulled the saddle forward out from under myself, done two revs more and then… UPD.
    I gave up continuing with SIF because of lack of any protection gear and besides that was not planned for today. Let’s not abuse bonuses and return to that a bit later…
…and preferably on a hard court. Unlike its name suggests it‘s rather soft, so falls hopefully hurt a bit less.
Unfortunately, there are no courts here. Neither hard ones, nor soft.
But there are rubber coated playgrounds. However, there are some peculiarities with such kind of surface: tough turning about vertical axis because of high friction, which can be partly compensated by higher tire pressure, and greater lateral drift due to deformation of the coating itself.
Anyway, falls are softly on them.
Winter returned here and the weather drove me from outdoor with 24" unicycle back indoor to return back to 20" one.
At first, the idling didn’t want to work at all. It didn’t look natural, but rather forced (remember the free and forced oscillations of a pendulum from a school physics course). Then the “auto-tuning” had worked, something had “clicked” and everything returned to normal.
Perhaps, that skill to retune is worthwhile to be worked out too. That concerns not only idling, of course.
It could be another application of my four unicycles. :upside_down_face:
Okay Gents,
I’m back, I had been distracted for a week or so, but I have continued to do my riding.
I hope changing the seat heat yielded some improvement in “feel” and also made your legs “stronger”
The discussion of the topic SIF is very interesting also.
It seems some of us like to just “go for it”.
This process:
a.) ride forward.
b.) stand up
c.) pull seat in front of you
d.) continue.
I am sure I have “tried” to do that, but “immediate” fear from so many variable changes told me to sit back down and ride. I believe most unicycle riders who have tried that method already have some “natural” balance When you stand in SIF position, all of a sudden your normal unicycle riding CG(center of gravity) has shifted. Most are not aware of this and just fall off behind the unicycle. Then when you become aware of this, we don’t “naturally lock into” the exact forward angle position that is needed. Just like any machine we have to adjust our “gain” back and forth. Problem is “too much” forward lean and boom you will fall on your face. Something a helmet doesn’t usually protect. Ouch.
That’s enough comment on this for now, if you followed another topic=“Getting Bored” I go into SIF a little bit more.
In meantime, let’s focus back on advance idling, which will naturally lead into backwards and SIF idling, once “we” all catch up and improve our skills.
…slam
I’ve been back on a unicycle for about four weeks now after a 10+ year hiatus. I can still do quite a few fancy tricks, idling consistently recently becoming one of them. I have never been able to idle SIF, whoever told you to learn that is a liar! Lol. I can pull SIF, ride, stand static, mini hop, recover and pull the seat back in and ride away no problem. Idling SIF is nothing more than a gym routine for your calves.
Focus on idling comfortably with your butt on the seat, that’s what will train the right muscles. Also, as circus related as it may seem, if you can juggle, add it to your idle training. If you can comfortably idle and juggle 3 balls at the same time, you’ve nailed idling. Idling uses your hips, juggling whilst balancing uses your shoulders. Once your upper and lower body are working together, youve nailed both skills.
Here’s a tip on SIF idling.
Press the saddle against your belly.
This instantly gives you more control.
Not only to stabilize the saddle, but you can manipulate the entire rocking action with your body against the saddle. Makes idling easier. Were you doing it the other way? Holding the saddle away from body?
Here’s a quick review of the advantages of SIF idling?
1.) The ability to control the unicycle lateral balance with feet only. Advanced idling. This is similar to an ultimate wheel but without dangerous forward movement.
2.) The ability to learn to “bail out” with pedals at 3 & 9 o’clock(that means flat pedal, somebody thought that means 90 degrees…no, nyet, nein)
3.) Well…duh, learning to SIF. If you don’t want to “risk” the stand up/pull out/ride SIF method, learning idling SIF would seem logical, right. Then add the forward rolling part.
More later in another topic posting…soon
…slam
Tonight I managed to ride SIF. I tried to start seat towards belly and roll back mount and then idle. No success. Then I tried static mount, best result one revolution and not a pretty one. Then I tried to ride with my butt as high above the seat as possible for a while and then slowly ease the seat out in front, holding the seat with one hand and pressing the seat towards the front of my thighs. 15+ revolutions mostly due to the size of the parking lot. So this method what works for me.
I also managed about the same distance riding backwards in the normal way. The progress I have seen this winter is really encouraging!
And soon the parking lot will not limit the revolution count because you figure out how to turn right and left.
Congrats on riding SIF backwards! I think I tried this once or twice without success.
Oups!
I see how you would get the idea that it was backwards SIF.
No backwards SIF riding, only regular backwards riding.
I have edited the text.
Ah, ok. I thought you were casually riding SIF backwards, which would be quite impressive in my opinion. :slightly_smiling_face:
