At NUC several people had the bike seat post with adjustable angle. Could
someone refresh my memory (just got my beautiful carb fiber seat with
wilder bracket ) ?
Oli-
opaugamATaptilonDOTcom !
wilder bracket ) ?
Oli-
I highly recommend the Thomson ATB seat post, available in different
diameters. The price everywhere seems to be about the same, US$80,
for instance:
http://www.performancebike.com/shop/Profile.html?SKU=6445&Store=Bike
Go down to a bike store that has this so you can hold it and see it.
Compare it to the other ones - I predict youâll like this one the most. I
cut off a little over 2" for my Telford as it is 330mm long.
âNathan
âOlivier Paugamâ <opaugam@aptilon.com> wrote in message
news:FD35DC6A97CB2A4DBEBA1152E54452330A5836@EXCHANGE.aptilon.comâŚ
> Could someone refresh my memory (just got my beautiful carb fiber seat
> with wilder bracket ) ?
> Oli-
Hey Nathan
Actually I just couldnât wait and my local bike shop did not have the
thomson ATB 25mm so I got a Alien S-1 instead. I will have it cut a bit
tonite to fit my pashley. The Alien is also a variable angle post with a
funky âslide & lock by pressureâ mechanism (130 $CA approx.).
I donât know yet how it will hold up on my saturday muniing.
Oli-
-----Original Message----- From: Nathan Hoover [mailto:nathan@movaris.com]
Sent: Thursday, August 23, 2001 12:13 AM To: unicycling@winternet.com
Subject: Re: adjustable angle seat post
for instance:
âNathan
> Oli-
Olivier,
If youâve got a wilder attachment then any bike seatpost will let you
adjust the angle. However, not all bike seatposts work equally well. Some
suggestions:
The nicest seatpost that Iâve seen is the Thompson seatpost. They are
quite expensive but have a very strong, low profile clamp mechanism. They
are also CNC machined instead of just stock tubing, which means that there
is no potentially breakable bond between the lower part of the clamp
mechanism and the post (instead these two parts of the post are one piece
of metal).
Cheers,
Kris.
[BTW Oli whatâs your real email address. The one you use here always gets
returned to me.]
Do You Yahoo!? Make international calls for as low as $.04/minute with
Yahoo! Messenger http://phonecard.yahoo.com/
