I need to know whether the Pyramid Series II does square taper or splined or both. I’d also like two know what exactly the other one does (squared taper? removes crank bolts? splined?)
It’s hard to tell from that vague site. The only difference between a normal square-taper puller and an ISIS one is the size of the part that pushes against the axle. ISIS uses a bigger bolt, so the end of a square-taper puller will get pushed down the bolt hole and mash up the thread. Quite a few of that type of puller (the pyramid one you linked to) these days work with both sq taper and ISIS, either with a stepped and or swappable ends. Probably best to ask the dealer.
I’ve not seen one like the other one you linked to - looks like it’s probably a crank puller of some kind, but in separate bits. Most of the ones I’ve seen look like the one in your first link.
