still wondering what size sprocket i need for my giraffe, i got 5" cranks
with a 30 tooth sproket, now i need to know what size gear will go on the
wheel…almost done and getting eager to lean…please help.
thanks jojotimes1@aol.com
> cranks with a 30 tooth sproket, now i need to know what size gear will
> go on the wheel…almost done and getting eager to lean…please help.
For best results, keep it close to 30 to match the other one. Depending on
the type of riding you will do, you can also gear it up some. But if you
plan to do tricks, juggle while idling, etc, don’t gear it up too much. I
think 26 or 28 teeth would be nice. Avoid 30 if you can, because then
you’ll always wear your tire out on one spot, just like a regular uni.
With a one or more tooth difference, you’ll get even tire wear.
Good luck, John Foss, the Uni-Cyclone jfoss@unicycling.com
www.unicycling.com
There can be a fine line between “hobby” and “mental illness.” – scary
reality-check for unicyclists
