28 spoke rim?
Hello I’ve bent my 28 spoke crapcycle rim so much it can’t be corrected
even by a real expert. Both bike repairers that have tried just sighed
something about “amazingly lousy rim”. Due to the unusual number of
spokes, my lokal bike shop couldn’t get me a replacement rim.
Does anyone have any tips on where to find a strong 28 spoke 24" rim?
If I can’t get a replacement rim, my next option is to buy a 36 hole Suzue
hub. (I think it will fit my “Cyclepro” with about 60mm between flanges
and about 16mm axle diameter.)
Thanks Staffan Palm, Sweden staffanpalm@hotmail.com
Advice: When buying a uni, make sure it has a standard number of spokes
(32, 36, or possibly 48) so replacement parts can be easily found. More
advice: Make sure it’s not a “Cyclepro” if you want to do more than going
to the mailbox now and then.
When I was hunting for a replacement 24" rim I didn’t come across anything
respectable with 28 holes. The only decent rims are built for downhill
mountain bikes as far as I know, which are moving to smaller rims for
increased manoueverability. Since they’re throwing themselves off
mountaintops, they need lots of spokes for lots of strength.
nic
> Suzue hub. (I think it will fit my “Cyclepro” with about 60mm between
> flanges and about 16mm axle diameter.)
> going to the mailbox now and then.
Hello along time ago i ran into this same problem the solution i used was
to drill 4 evenly spaced holes in each flange as i remember a bit of
thinking went into the offset of the holes in respect to each side I may
of used slightly longer or shorter spoke also. Aaron anderson
P.S. to make this more clear look at one flange it has 14 holes
drill a new hole between two holes then count 4 holes and
drill then 3 holes and drill then 4 holes and drill. It was a
while ago but i think i offset one hole to the right on the
other flange holding the hub with the already drilled flange
closer to you. Put 4 holes into the other side Then lace it
as a 36 spoke wheel.
> anything respectable with 28 holes. The only decent rims are built for
> downhill mountain bikes as far as I know, which are moving to smaller
> rims for increased manoueverability. Since they’re throwing themselves
> off mountaintops, they need lots of spokes for lots of strength.
> nic
> > corrected even by a real expert. Both bike repairers that have tried
> > just sighed something about “amazingly lousy rim”. Due to the
> > unusual number of spokes, my lokal bike shop couldn’t get me a
> > replacement rim.
> > spokes (32, 36, or possibly 48) so replacement parts can be easily
> > found. More advice: Make sure it’s not a “Cyclepro” if you want to do
> > more than going to the mailbox now and then.
