27.5 Muni - steel frame - Velocity rim
[SOLD]
Edit: $350 + shipping
$400 + shipping
-29" Nimbus Steel Frame. Worn down from shin pads, with surface rust.
-27.5" Velocity P35 Rim.
-Nimbus 48H steel hub, laced with 32 spokes.
-Maxxis DHF 27.5x2.5" WT DH casing
Setup tubeless. Seems to leak air over a few days time, so some sealant or new rim tape might be needed.
-Shimano disc brake. It is quite noisy right now. I haven’t used it in a while, so not sure if it might just be inherent to the D-brake setup. Not sure if cleaning/rebedding the rotor/pads will help; too cold here for me to go out and ride. Welding a tab to the steel frame would be a good idea.
-KH Freeride Saddle with enforcement plate
-KH T-bar
-KH adjustable seatpost
-150mm/127mm KH Spirit Cranks
-Metal Pedals
