Is the only reason people don’t use 16" wheels for trials that they’re not available with strong rims and fat tyres?
I know that unless I could be convinced otherwise, I’d definately choose a strong 16" uni over a 20" for trials. It’d be considerably lighter, and I would’ve thought it’d be better for technical stuff. I know it’s a long shot, but are there any good rims and tyres for a 16" trials uni? I guess it’d be a 15" rim or someting like that. Would 127mm (I’m thinking QU-AX) cranks be too long if used specifically for trials?
A 16" with Qu-ax 127mm cranks is indeed an interesting prospect!I think there is an Alex DM24 in 16" size. Max Dingemans will know, as his Dad has built some custom 16 inchers.
The Maxxis Hookworm is one of the better 16" tyres. I’ve not seen a good knobbly though…
i’ve been thinking about this for a while now and my fdirst idea was to weld two crummy(from the scrap heap)(lack of money) 16" rims together and run two standard 16" tyres side by side. lace the spokes onto one 36 hole(48 if possible) suzue hub. then make a frame to fit (already made some 20" trials and freestyle frames). i might do this after i’ve payed for my new 20" trials:D .
another idea was to get a 16" motocross rim and v wide tyre, lace this to a suzue and away we go;) . only problem is this will be v heavy but it will be v cool.
Im amazed, after an extremely short research attempt, the Alex DM24 does come in 16", but only 16 hole. I think the ryhnolite comes in 16" 36º, and thus would be a better option. but again, the hookworm would be the best tire I have seen for 16’s.
The more standard 20" (well actually 19") Monty tire would be a better choice. You will get much better bounce from the fatter tire and the fatter tire will also absorb drops better. Fatter is better all around for trials stuff. The lighter weight of the 16" wheel will not make up for the lack of bounce in the skinnier tire.
A 16" trials uni would be a fun toy if you already have a 20" Monty trials uni, but it wouldn’t make a good primary trials uni. I’d consider a 16" trials uni a novelty item.
I was only being half-serious. If there was one available with a strong 15" rim and a nice big 2.5" tyre with good grip, I might get one instead of a 20" trials uni. I’m actually currently saving up for a 20" trials uni. Hopefully I’ll have it before UniNats. Eventually I’ll get a 16".
Sorry, because I’m sure this has already been mentioned, but why are you selling it? I’m actually saving for a GP trials uni. It’ll be much cheaper for me that way.
